Started this morning and 3-4 hrs later it’s installed minus the wiring.
.....I used the ABS wiring for the constant power (black wire with white stripe) and ground (white wire with black stripe). I removed the 60amp ABS fuse and replaced it with a 40amp. For the 5amp ACC wire, I cut the wire going to the defunct rear heater and connected to it, replacing the 20amp fuse with a 5amp.
Great idea! That’s why I love this forum. Do you have a picture of the wiring? I just want to make sure I’m wiring it correctly. Thanks in advanceJust finished getting the iBooster kit installed this afternoon. Removing the original vacuum booster was probably the biggest headache due to interference with the intake. I ended up using a reciprocating saw to cut the studs to be able to remove it.
Since I had already deleted the ABS and LSPV, I used the ABS wiring for the constant power (black wire with white stripe) and ground (white wire with black stripe). I removed the 60amp ABS fuse and replaced it with a 40amp. For the 5amp ACC wire, I cut the wire going to the defunct rear heater and connected to it, replacing the 20amp fuse with a 5amp.
@torfab This seems like a great option to bring our 80's up into the modern world of braking. Thanks for developing this. A couple quick questions:
- Pretty sure the answer is going to be yes, but I assume that this will improve pedal feel, and I don't have to go half way down the pedal stroke to start actually braking?
- Would you consider stainless steel lines a requirement for this setup, or would Toyota soft lines (installed 4 years/35,00 miles ago) be sufficient?
source for these little bench bleeding fitting please?Started this morning and 3-4 hrs later it’s installed minus the wiring. View attachment 4191311View attachment 4191312View attachment 4191313View attachment 4191314View attachment 4191315
I suspect the main thing is that they don't want people blowing out 30 year old lines and trying to blame the new booster. I would think you'll be fine.@torfab This seems like a great option to bring our 80's up into the modern world of braking. Thanks for developing this. A couple quick questions:
There are kits all over Amazon for a few bucks.source for these little bench bleeding fitting please?
N
That’s what I suspected as well. Thanks.I suspect the main thing is that they don't want people blowing out 30 year old lines and trying to blame the new booster. I would think you'll be fine.
N
On some of my other vacuum ports that I have capped, I put a small section of new hose, about 1" worth on the nipple, and a stainless steel ball bearing down in the hose to plug it.I got mine at my FLAPS (friendly local auto parts store).
Probably a stupid question, and quite
likely addressed in the instructions, but I assume that the brake booster vaccum hose is no longer needed. What are people using to cap the vacuum nipple?
For now I just stuck a big bolt in the line and used the clamp that's on it.I got mine at my FLAPS (friendly local auto parts store).
