Bosch iBooster Brackets for 60/80 Series – Tested in Moab, Ready to Go
Everett, WA
Website
www.torfab.com
Hey everyone,
We’ve been developing a Bosch iBooster mounting bracket for Land Cruisers, and I finally got a chance to put it through a proper test.
I installed it in my 80 and took it down to Moab—hands down the best braking performance I’ve ever had on this truck. That’s with otherwise stock rotors, calipers, pads, our stainless braided lines, and ABS removed. Pedal feel is solid, consistent, and confidence-inspiring both on and off-road.
These brackets are in production, and will be released in the coming months
What it is:
A purpose-built bracket system to mount the Bosch iBooster cleanly and correctly—no guesswork, no cobbled setups.
Key points:
  • Proven in real-world use (Moab trip, not just around town)
  • Proper pedal geometry and alignment
  • Clean, repeatable install
  • Ideal for low-vacuum setups (modern engine swaps) and diesels without vacuum pumps
  • Eliminates the need for hydroboost or vacuum-dependent systems
Fitment:
  • 60 Series
  • 80 Series
  • Likely 40 Series
  • Should also work well in Toyota mini trucks
(Not really intended for 100/200 series)
Pricing:
Still dialing this in, but likely landing in the $300–$400 range with harness for a bolt in solution.
Why this matters:
A lot of iBooster installs end up being one-off solutions with questionable geometry. This solves that problem with something repeatable and built for actual use.
What I’m looking for:
  • Interest level from anyone planning iBooster swaps
  • Demand for additional chassis (if any make sense to pursue)
  • Any edge-case fitment concerns you’ve run into
Photos of the setup are attached
-Tor
Torfab Land Cruisers
I would be interested in this for my 93 80 series. It still has the 1fz, removed ABS with manual proportioning valve. Brake feel has been.. uninspiring to say the least.
Will this be a whole kit or require additional parts?
I'd never heard of the iBooster before. This looks like the type of motor driven boost system that is on my '06 GX. I had actually been contemplating how to adapt the 4Runner/GX master/booster for my '97 80 Series, but this looks a lot easier.
Will this work with the ABS still in place?
The pic looks like a salvage yard booster is used, what is the source for the iBooster itself?
I’ll volunteer to put it on my 72 fj40. My 80LC MC fell apart so I’m doing brake lines, master cylinder and booster. I’m 4 wheel disc. Keep me in the loop! Thanks
This will be a bolt in kit, using your existing master. The whole combo puts the master cylinder about 1" forward from stock location
This will work with ABS with just a couple lines being bent to make it fit.
Count me in. My brakes have been needing attention for quite some time.
