Build BoltRipper's 2-year Overdue Build Thread
I need to drive it more, but it was a bit delayed from the usual spot when I turn into the driveway... I doubt it took are of it, but like I said, its not the bad ones that some experience.
Maybe the sound of the 4.7L will make me forget about it....:flipoff2:
Received word from Onur that this arrived today from Japan.......
I'm not telling yet :cool:
:cheers:
Here are some other pics that Onur just sent.... Should be clear now.....
Thanks Onur - Appreciate you getting this in and doing your inspection.....
:cheers:
Figured it was time for some love to the rear axle. Started with some MAP Gas and a different striking point to remove the cone washers... This method was easy.. Just enough compression to set the washers free.
Not too bad, but it was in need of an overhaul.....
Clean it up and remove the two lock screws on the retaining nut..
Drivers side had no preload and the nut spun off with just finger pressure.
Pull the axle nut washer off and remove the hub assembly.
Pull the oil seal
Reinstall a new seal...
Prepare your new OEM parts for install.... Thansk to @beno
Remove the rear seal on the hub and knock out the old races...
Clean the hub and chase the stud threads....
To be continued.....
Install outer race first..
Install the new studs...
Pack the bearings for install...
Pack the hub with grease and install inner bearing...
Rear Seal is next... Some people say they have trouble installing due to the size....... Just use the old race to install...
Rear Seal installed.. Smear grease around the hub seal and you are ready to install.
Install Hub and insert outer bearing....
Retaining washer...
Nut and torque to spec... Install lock screws...
I made my SST tool like others have.. Worked great...
Outer gasket...
New Hardware...
Torque to 26 ft/lb
Done....
:cheers:
Interior Continued: USB Additions
So my 9 and 11 year old girl's don't smoke and neither do I, so I was wondering one day what I could do with these.....
Seems every device we have from cell phones to tablets utilizes USB charging. I figured that I could do a neat mod and remove the ashtrays and fabricate USB charging ports...
After completing the center console modifications, I was getting good with the ABS/Kydex so I started making some plates to hold a Blue Sea USB Port.
Here are my cover plates ready for install in the rear doors....
The thinner rear plate goes under the window switch molding and the Blue Sea USB Lock Ring sandwiches them together for a very tight fit.
Next I made up some custom wiring harnesses with abrasion resistant covering.....
Here is the finished look....
Couldn't neglect a possible 3rd person sitting in the middle and not having a charging port, so I installed a third Blue Sea USB port on the rear of the center console.
Next came the Front and Rear of the vehicle. I ran a USB Port on the driver side rear panel...
Then I decided to place a Blue Sea dual 12V and USB Outlet on the Passenger side so I could have a very short run of wire from the distribution blocks to connect the ARB Fridge.
BAM... Another ashtray GONE....
For the rear 120V power I utilized a shallow mount residential box from Lowe's, and fabricated a flush mount cover to finish off the install.
Finished the rear Electrical off with the addition of a OEM Dome Light installed onto the lift-gate. This adds light for getting into the ARB Drawers and camping.
For the front of the vehicle I ran power from both the Wagan Inverter and also the Blue Sea 12V Distribution. below you can see all the wiring being brought to the front of the truck. I sleved the wires in abrasion resistant covers for a clean install and protection....
Made a small modification to the center console to bring all the wires up to the dash for their respective parts.
You can see in the below photo the Toyota Matrix 115V switch that I utilized for the install. The switch is correctly wired through a 30AMP Relay to the Wagan Inverter and I was able to figure out the pin-outs on the switch to get it to light when activated and also back-light when the vehicle lights are on.
You can also see where I made a custom bracket to mount the National Luna Dual Battery Monitor.
:cheers:
where did you buy all of the ABS/Kydex for this project? what are the specs on the material you used and rough est. of cost?
I really dig the ash tray idea... !!!
I get most of my stuff from McMaster Carr and Amazon.... The Kydex / ABS Sheets came from Amazon.. Probably $12 for a 12"x12" sheet. I cant remember the size off the top of my head, but I measured the ashtray thickness and purchased the closest they had...
:cheers:
I kind of have a boner, subscribed! I'm pretty jealous of what you've done so far, and props to the meticulous side if your work, well thought out and it shows with your finished product. No need to "keep it up" cause you will, how about "anticipating the next mod, rebuild, fluff, or this 4.7 that just became the new drool mod! Hmm... Keep kicking ass!
Nice rims are those AR and did they come that way in black>?
Which wagan inverter did u purchase? Experiences with them?
Amazing build!
Amazing build!
Wagan ProSine 400W... This is the first one I've had and it works great. I've run a portable fan and also for rapid charging my cells and ipad and PC & Mac Book pro.. No issues so far ...
Thanks.. been looking for one for my Chinook project..
Impressive commitment
Thanks Nors...
I have committed to this truck as she is headed to Slee this Saturday July 11th for an 8 week +/- spa treatment including a 4.56 re-gear and Slee 2uZ-FE swap..
I'm looking forward to many more years with her..:cheers:
