Bolt size rear propshaft?
The Netherlands
Does anybody knows the bolt size for the rear propshaft or where to order them?
The thread pitch size is 1.0mm and is same as the front but a then thicker.
1927257
Kind regards, Rene
The drive shaft hardware is unique to the application, best to get it from the dealer or a Cruiser parts supplier.
That does not look like an 80 Series transfer case to me. There is no stake nut on an 80 output shaft.
If you are looking for the studs in an 80 flange they are not serviced. Officially you have to buy the output shaft to get them. I have heard that 100 Series studs, 90114-11003, will fit but I have not independently confirmed it.
Nuts, 90179-11005
Washers, 90201-11013
Nuts, 90179-11005
It does look like a split case. 90114-11124 would work since it's already specified for front and rear output flanges on the split case.
I think that might be an 80-series part time transfer case (not sure what nomenclature that one is called):
(photo is not mine, got it from Google)
I would imagine it would share the same hardware as the full time application, but maybe @beno and @cruiserdan could confirm?
On the other hand that could be a "stock" photo grabbed at random to illustrate the needed item(s).
I have been looking through catalogs I can access and I have not yet run across an 80 with a case like that. Any idea what the original application would be? The OP neglected to mention what model he was working on. It may not even be an 80 and he landed in the wrong forum.
Found one.
1990 General Countries HDJ80. HF1A.
The flange for that is a 33309-60090. The studs are not serviced in that one either.
True. Good point. He is overseas so that might be a part time case for an 80, but the 80 cases do not have stake nuts. :meh:
The HF1A I found did have a removable flange with a stake nut.
As I mentioned above the studs for that removable flange are not serviced so it could be a toss-up as to weather the 60 studs or the 100 studs would work in it.
A reverse-lookup on that part number shows it used on 70 and 80 Series only.
Interesting. You are indeed correct sir.
Wizards
