mattressking
10 digits to freedom
- Location
- United States
I realized I don't plan to own a '73 anytime soon or ever and having it sit in a box is ridiculous, so I've decided to list it. The price is high....to reflect the inability to find them except through @65swb45 or some other difficult means. If you're doing a restoration, this is for you. I cleaned the lamp and straighted a number of dents but left in its original condition. The power wire was cut down so I added a female bullet connector. If you need a jumper to connect between the body I can whip one up and include.
Condition - the lamp housing itself is slightly corrodded, see pictures but the bulb housing and wiring are in beautiful shape. If you wanted it to be replated, that would likely be the only way to get a completely reflect surface again. There is no pitting so if you blast and replate, you should be in great shape. The body is in good shape, nearly perfect but again, I wouldn't mess with it unless this is a concours vehicle. The body gasket is in beautiful shape, very pliable and still shows all original TEQ, Koito and Toyota markings. The bezel is nearly perfect and the lens is in perfect condition. The lens gasket was long gone so I whipped one up with some 5mm closed cell foam. You get two options for bulbs and I belive I have a new genuine Koito bulb as well so I can include.
The original screw heads were toast so once removed I swapped for new OEM screws.
Price - $485 shipped and insured.
