Pump is newish. Replaced with kyosan 12/2018
I'll probably try this. Seems like a low intensity kind of effort to maybe get some trash out. When you say "flushed from the top", exactly what did you do? I mean if you take off the top plate don't you have to replace a gasket? wonder if I can just spray it out with some carb cleaner from the 14mm bolt hole?
Here’s a step by step from an old post by Jim C. ( It’s for a 40 but is accurate for our 2Fs.) I just removed the bowl drain plugs and sprayed from top as he describes. That fixed it for me. His complete method has a few more steps but is still very basic - carb stays in place and intact. Agree with @cps432 that you should be spraying from above, not below, so you don’t push anything back into the jets or bowl via the drain holes.
From Jim C:
How to (maybe)clean a 2F carb without tearing down.
- disconnect both fuel lines.
- remove fuel inlet fitting and fuel return assembly
- remove bowl drain plugs, placing a rag underneath to catch the spilled fuel.
- using Gumout spray carb cleaner, blast in the fuel inlet and fuel return, alternating. Chase w/ compressed air where avalable. The sand & crap that is piled up at the inlet screen (visible when looking in the inlet hole), can be moved/removed by blasting back & forth w/ the carb cleaner. Also, since the float is fully dropped now, the small bits that made it through the screen will fall through the wide open needle valve, allowing it to control fuel level better when the bowl is refilled.
- using Gumout, spray in the brass vent pipes in the top of the carb throat. The gumout will wash out of the drain holes on the front of the bowl, carrying some of the loose sand & dust out of the float bowl.
- remove idle mixture needle. Spray gumout in mix screw hole, while holding throttle open, so the idle port is uncovered. Put mix screw back in all the way, back out 3.5 turns.
-Place a clean container under fuel feed line. crank engine to get a cup of fuel. By running the fuel line wide open, much more gas is flowed than normal, washing loose junk up & out of the feed line. Junk that just moved around in the line before, but couldn't really get out.
Reconnect lines & install drain plugs, see if it runs any better, check float level.
This will often make an improvement on an old FJ40 w/ dirty tank that is blocking the trail for everybody else
