Boggers installed backwards
BC
Maybe a stupid question but why do I see pictures of trucks with the boggers installed backwards?
Because people do not realize they are directional?
Because people are trying to be different?
Because people are concerned about going into the mud too far and not being able to power out in reverse?
Years ago there was a road test of a unimog in Car&driver magazine. Many readers wrote in to point out the error that the chevrons were installed backwards on all the trucks. C&D asked M-B for an explanation.
M-B said the chevrons were lasting longer on the street when running backwards.
I think the krauts couldn't admit they made a mistake.
Interesting theories...I see it all the time in magazines and had to ask.
In the agricultural world, chevrons on trailers are often mounted backwards because there is less rolling resistance. On a power axle it provides less traction though.
Mark...
The same situation arises in mountain biking with respect to tire directionality. Often the front and rear tires are mounted in opposite orientation for braking (front) vs traction (rear). It does make a difference which way the biting face is oriented... rolling resistance can also be affected by orientation, and in certain racing situations a tire will be mounted "backwards" to reduce friction that slight amount.
Okay so I figured I’d open this back up. Kumho road venture they are directional. For the road like a performance tire. All the chevron tires backward would do is when ever you turn your wallet in your back pocket would squeal because the lugs would rip right off making you not driving as far leading to less wear. Bloggers mounted backwards are an awesome option for the bigger head.
