Body mounts install
Lot of debate on the forum about the best mounts. Another option from TPI4x4 (coolerman from ih8mud?):
Though sor's website lists the energy suspension bushings as softer that oem. I'd assume these TPI mounts to be a similar durometer (stiffness) compared to the oem mounts.
Can I ask another question about the new body kits? How tight should I tighten the bolts one the new bushings are installed?
I cannot find anything about this part of the process.
I swapped out my body mounts. Not to be dramatic, but I hated every minute of it. It's never as easy as replacing the old with the new. Some had to be cut out; some bolts broke, leaving them trapped in a tough spot. I ended up having to punch out a few with an air hammer. Oh yeah, and Energy Suspension provides these super nice metal plates with a welded-on nut. They're really nice in every area except spot #1, where they are too thick. Took some modification and a ton of curse words to get them in there.
In the event you happen to break a bolt when removing the old rusted ones, I pray for you.
