Build Bluebonnet - 5.3/H55 FJ40
I’ve been painting for the past few days. Worked on this set of 5 stock 40 rims I picked up from @Tank5. Wire wheeled the rust putting on the surface and finished them up in Rustoleum Dark Machine Grey, pretty close match to OEM.
View attachment 2714052View attachment 2714053View attachment 2714054View attachment 2714055View attachment 2714056View attachment 2714057View attachment 2714058View attachment 2714060View attachment 2714059
I did the same, only I used satin black. I put on a few coats of clear on top of that and it has held up nicely for several years.
Started mock-up of the 60 series power steering box. Carved away at the stock Fj40 shock tower while maintaining 2 full ribs perpendicular to each other for support.
The original plan was to plate both sides of the frame but plating the outside of the frame would move the u-joint too far into the center of the shock tower. After consulting with a few mud members we decided it would be safe to do without the outer frame plate.
Drilled both sides of the frame and lined up the plate and DOM tubing with the box mounted and burned it in.
Ground the outer frame channel flush
Plan on boxing this portion of the frame next, need to purchase more steel.
Make sure to check that the drag link doesnt hit the left spring when left front is in compression - you may end up wanting to swap to a 80 series pitman arm
The 2.5” lift OME goodies came in today. Installed the new springs and bushings and torqued and greased everything up. The new kit didn’t come with new hardware for the shocks so will get those in later.
Also moved my rear axle to the forwards hole because OME tends to move the rear axle too far forwards in the wheel well and it looks funky. Thanks for the heads up @cruisermatt
I’m working on my patina 71 right now. I can’t wait to see that blue pop with the CLR and fluid film treatment. It’s going to be amazing
your lower U-bolt plates with the shock mounts are on backwards though ;)
Per Dave Gore at 4plus, install of lower shock mount is correct. You must be thinking of 60 series where shocks are in front of axle?
Interesting - didn't realize that's a thing. What's the scoop there? I put on a OME 2.5, and I'd agree that the rear axle did seem a smidge forward. Chassis is still all bare, so now is the time for me to tweak anything.
Had my OEM (I know they don't fit, but, this was in the days of dial-up internet) and, later, Rancho 2" springs rub 33s on the front of the rear wheel well. I finally moved the axle back, so I didn't loose any more Mud Terrain knob with suspension compression. That 40 had a horrible ride, but, it looked great, standing tall with high heels, and all. No driveshaft mods for the extra spring curve, and extended wheelbase, but, I also had a (longer) SM420 to replace the 3-speed that drank water, probably thru the shift tower, so I didn't worry about fully extending the (shorty) factory slip yoke.
