He didn't open up anything. I think he went just by the noise and that's it.if he drained the oils, make sure there is oil back in the diff and/or transfercase
Beat my by a second. Both clips are in and things look ok?Happened to me last summer. CClip popped off, axle slipped out and stripped the drive flange. Drove fine with center diff lock on. Had to replace axle, flange, clip and repack bearings.
Good call. I'll do that in the morning.Drive it slowly around the block with the flanges off. Disegage the CDL and see if the noise is still there.
He said in the transfer case, not the diff. And he may have been stretching it and just going by the sound it makes. I'm never taking a car back to those guys.I thought in your first post, about bearings everywhere in the transfer case that he either drained the oil or had a look inside.
drain the oil in the front diff and see if it is chunky and shiny.
Good call. I will check that as well.but now your thinking the issue could be the front diff, if something is bad in there, you will see it in the oil.
There is still a whirring noise with the flanges off. I can see the shaft ends spinning with the flanges off.Drive it slowly around the block with the flanges off. Disegage the CDL and see if the noise is still there.
Before you pull the trigger on a transfer case...
Usually when someone posts about a blown/broken transfer case, it isn't the transfer case at all. It's usually an issue with the "front axle to drive plate interface". Usually when one has this issue the truck will move fine with the center diff locked, and make nasty grinding noises when the center diff is not locked. If the problem is with the 98 LX in your signature, and my memory is correct, the 98-99 year models automatically locked the center diff when they were shifted to 4-low (2000-2007 models require you to manually lock the center diff with a dash switch). I'd check this before I purchased a transfer case.
forum.ih8mud.com
