Blowing EFI Fuse (shorted O2 Sensor??)
Orlando, FL & Southampton, NY
OK, I just got done replacing the entire exhaust system from the Y-Pipe all the way back :cool:
Went to start her up and she cranked, but didn't start :confused:
EFI fuse was blown, replaced it and it blew again as soon as I turned the key :hhmm:
Since the only wiring I messed with were the O2 sensors, I checked the harness at both sensors for kinks and all looked good....
Disconnected the rear O2 sensor and she started right up :)
Plugged it back in and she blew the fuse again :confused:
Disconnected both O2 sensors and checked the heater circuits with my Ohm Meter as per FSM....
Both read fine at 14ohms across the HT and B+, however, the rear O2 shows continuity across the HT and the other two wires that typically aren't tested :hhmm:
Checked for continuity on the same wires on the front O2 sensor and both wires are open :meh:
So I'm guessing the rear O2 sensor somehow got shorted when I removed it from the old exhaust :hhmm:
It was rusted to hell and I had to use an air hammer to chisel the studs off :doh:
Anyways, has anyone else run into this problem before?
Rick
had the same problem with mine. turned out, my old exhaust mount had broke - causing the exhaust pipe to short out the rear wiring harness- burning the wires all the way back to the plug in connection- melting all the sensors associated. The FJ80 would run, but- the shifter would not shift without pushing the shifter over-ride button. But, the ECU fuse would pop as soon as you stuck one in. New harness and new sensors- no problem since.
Rick
I just bought denso O2s from rockauto.com. About $130 for the pair.
Wiring checks out fine, although, I did have the same problem with my 2TZFZE Previa where an exhaust leak burned right through the O2 harness :doh:
No $h!t??
I just paid that for the rear alone from Mr. T :doh:
It arrived at my shop today, but i won't get a chance to install it until tomorrow :meh:
About 4 years ago, before I found out what a Land Cruiser was...I was driving mine at 70 mph in Georgia, left lane, tons of traffic...and everything shut off, threw it in neutral, squeezed between a couple of cars to the right and pulled off (no space to pull off into median, they installed those high tension wire medians).
Shorted O2 sensor. Someday I should replace the other one, but my gas mileage improved after it was unplugged.;)
