Blow By and the PCV
North Front Range, CO
I think my blow by is more than my PCV can handle. I replaced the oil fill cap and I still get seepage at the cap. Is there anything I can do?
I did once vent the valve cover with a couple filters but removed it as the oil smell in the cab drove me crazy.
I just reinstalled my home made catch can. I will see if that helps but that will only remove crud from going back into the motor.
I dumped in a qt of Lucas Heavy Duty Oil Stabilizer. Will see how this works.
There will be no rebuilding as rust is starting to have its way with the body.
I just want to keep it running till Oboma is out of office.
Landtoy80; Something I noticed recently when I had my valve cover hot tanked last week. The baffle system riveted to the top of the valve cover was completely clogged internally with sludge. I have no idea how that system is supposed to work but the baffle is sealed and riveted to the top underside of the valve cover and has a few different holes in it, I'm guessing for air flow and to prevent (?too much) oil from being sucked up. It struck me that if the baffle were clogged up it would have to have an effect on the flow of gasses and oil mist out of the valve cover via the PCV valve into the Throttle Body. Just thinkin.
I don't think you want the stuff from the catch can back into the oil pan.
