- Joined
- Jul 12, 2005
- Threads
- 56
- Messages
- 371
- Thread starter
- #21
Thanks for all the advise. Great pictures of tools to help me today. Will make a run to the hardware store for the fittings to try a combo air/water approach. I did get some sediment under the thermostat from my 50 psi approach yesterday that I did not think did anything.
I have removed the thermostat w/o snapping the bolts on the water housing
. Bolts were very rusty and will have to inspect to see if the aluminum threads still grip -- hope so. Radiator stop cock does not yield water -- I guess no surprise. Just more time. Dropped the radiator water last night... did not look too bad. Now with hoses off I can back flush.
I assume I should disconnect the belt to allow the water pump to spin for back flushing??????
Will probably have the radiator cleaned after I get all this crud out.
You all have great ideas and keep throwing in you $.02
. Bolts were very rusty and will have to inspect to see if the aluminum threads still grip -- hope so. Radiator stop cock does not yield water -- I guess no surprise. Just more time. Dropped the radiator water last night... did not look too bad. Now with hoses off I can back flush. I assume I should disconnect the belt to allow the water pump to spin for back flushing??????
