Blackmamba (2 Viewers)
Thanks,
Is it the polyurethane body mounts, bought at www.sor.com;
Yes, it is the FJ80 master brake cylinder, bought at www.drivewire.com;
The brake cylinder booster is the 1982 BJ40 original part.
Sinse the bellhousing was in contact with the firewall, i had to increase the body. I made a 2,5cm Teflon mounts and added to the polyurethane ones.
Best Regards,
Very nice mod! Engine sounds great! :cheers:
What next? SOA?? :hhmm:
Yes indeed!
I have already the 3 hole spring perches, the hi steer, the anti warp support, and many other parts.
I also studied, in the Tech Section, the Andre Shoumatoff (Complete Overview to the SOA) many times.
The cut and turn should be the best part :bang:
More Stuff to install :wrench:
Blue Sea Systems - 12 Circuit with Negative Bus:
Ballistic Fabrication - Weld Plugs
Having problems with the pictures for some reason , I dont see them.
Now it time to return to the garage and make some adjustments:
Cut the right wing of the oil pan
I also turned the parking brake support and made some heavy duty t-case armor :grinpimp:
