Blackmamba (1 Viewer)
Finaly i got my adapter: 15B-FT - H55
Done a 4runner bolt pattern on the flange and disk, to mate my 4runner double carden driveshaft.
Clutch Bearing and Fork:
Left: BJ40
Right: Dyna 280
Test with BJ40 parts:
Short Fork; Small Pin; Bearing OD small.
Test with Dyna 280 parts:
Large Bearing´s ID (an adapter was needed)
Just need the rubber dust shield ;D
Clutch Disk:
Left: Dyna 280
Right: Isuzu ELF NPR59 (engine 4BD1T)
I used the isuzu disk because is has fine splines.
Engine Flywheel weight (Dyna 280) = 18kg
Clutch Disk assembly:
Unique!
Cool truck my resto is starting soon where do you source your parts in Europe still need a few things
Hi Rusty Phillips, it is a Nissan Patrol Y60. ;)
Hiluxonian, if you tell what part, i could tell you exacly where i bought it.
I am from Terceira Island (where the LAJES AIR BASE Nº4 is located) and i shop at Australia, USA, UK and Portugal (of course).
Regards,
Nuno.
Reinforced chassi/engine mount completed
Hope, the engine vibrations and Heavy Offroad, do not crack the chassis :)
Next step, forward the gearbox cross member!
Wow! I'm impressed Vaskalcorp!
Great ideas and great fitting & fabrication skills too.
The only area of weakness (I see) is your welding ...which looks "borderline". But then you're obviously already aware of that. And with more practice I can see you soon becoming an expert in that field too.
Great photography here too. .... Your thread is really informative and your efforts are really being appreciated.
:beer:
