Birfield Maintenance
Hi all, what maintenance, if any, is required for Birfields? I just had the front bearings on my 80 series repacked but wonder if I should be doing any regular maintenance on my birfields? Any greasing required? Thanks mates.
You should Be checking grease level every oil change use a zip tie or whatever and dip it into the fill plug on the back top side of the knuckle. If it’s low add accordingly with a grease gun and fortified molly grease. You want it 3/4 full.
Red circle is full plug.
Thanks mates! So fortified molly grease is simply good grease, like the red stuff sold by AMSOIL, and the same stuff I use to grease the rest of the truck. Correct?
Ask @jonheld what version he has used since Dinosaurs walked the Earth.
Amsoil discontinued the GHD moly grease that I used to use. It is now GPOR which is a relatively new product. I still have a case of GPTR which I have been using up.
In any case I've always used 1 grease for everything on the truck.
