Birf soup WTF??
Buckley, WA
I was leaving to go to lunch from work yesterday and I noticed what at first glance I thought was engine oil on the diff housing (front axle ;)) Closer inspection it looked like birf soup coming out of the top of the diff housing where the r/p bolts into it. None of this coming from the hubs or anywhere else on the axle that people normally talk about getting birf soup.
Has anyone else experience this? I think I narrowed it down to my diff breather being clogged and the axle bringing in some grease to the housing when I hit a few water crossings a few months back.
Looks like I got to tear into the axle again (I did the axle job about 7-8k ago and the wheel bearings about 2k ago)
I think i'm just going to take the r/p out clean the housing, put new gear oil in and new seal on the housing.
If it appears again then i'll replace all of the axle seals also.
Does this sound like a good plan of action right now??
I'll try to get some pics up by later today.
If you are not planning on replacing the axle seals, I would just drain and fill the diff oil a few times over a few hundred miles. I don't think the grease will really hurt the R&P, such that you need to remove it and clean it. Curious to hear what others think...
Yeah I considered doing that also. I think if I replace my diff breather and change the oil it should be alright but I also should replace the seal around the diff housing.
I wouldn't expect to see something coming out of the top of the housing
I regeared so I R&R'd my diff housing
Fist, its heavy, get a friend and a jack
Second, use plenty of Toyota Red FPIG on top of the gasket all the way around. I first used a gasket and didn't rip it and it was leaking so I had to do it all over again, Thats when people said "Oh you should have used the FPIG, thats what happens when you don't"
