It has somewhat started. Picked up the NV5600, I am waiting a few days for it to be pulled out of the truck. Got it complete with Dodge pattern backing plate (you can change the bolt pattern on these), bellhousing (which I will probably have to replace), flywheel, clutch, slave and master, trans mount, Dodge pattern starter, all for $2100. All with about 36K miles on them.
Bought a built Dana 300 for $700 off PBB. If I want gears it will be another $600 and I need to get the correct input shaft for $300. So it adds up. I will be $1600 into this t-case easily. But it will be built and 4:1.
Finally of course my Lincoln 135 is not up to snuff for this project. So I have been looking at welders. Looks like I will end up with the Millermatic DVI model, sort of like a 175 on roids, not quite a 210. Going to sell the Lincoln for $500 and basically have all the functionality (minus as much portability being the only loss) for $500 more, plus a 230amp machine, brand new. So I am pretty psyched about that.
I have also been looking at the wrecked 80. I have to pull the right rear hub off because the 6 lug studs sheared off in the wreck! The chassis needs to be rolling before they put it on the machine to see if the frame is straight. That will be $90 to check. I can't believe the extent of the damaga (KliersLC's old 80, the one wrecked from the u-haul trailer). If its straight I will take it. Also got a better deal on the frame from him. I might help him swap the engine / trans / t-case from this 80 into his current 80 for some trade.
Going up to Oregon over Mem weekend to pickup the new 55. Not super pretty as it sits (on some Dukes of Hazard rims) but is pretty close to rust free... I will start posting up pics of these things as they materialize...
