275/70-18 cooper discoverer at3 XLT E.Tire size?
Any higher and it will look like I missed leg day (and I’ll need 295/70s)
After 500 miles and a nut and bolt check i had the truck back up on the alignment rack at my regular guy. At perch #3 (1.8”) and aftermarket uppers I’m at 5+ positive caster. My alignment guy gave me a 30 minute speech about how I should switch to SPC because all the adjustment is at the top and it eliminates messing with the lower arm adjusters. I knew at that low of a perch I would run into this issue but I was surprised he recommended SPC.
Right now I’m at 1/8th toe out and 1/4 degree negative camber both sides with minimal to no rubbing. Before the lift it was zero’d out. I’ll drive it like this for a bit, I have some work projects coming up that required me to have to have a working off road vehicle so I’ll address this later in the month, perhaps with OEM arms. I’d much rather be in the 2-3 degree range than 5+.
Swapped Built Right CroMo Uniball/Poly Uppers for Dobinsons Tubular Ball Joint/Rubber Uppers and went up one clip to #4. No more binding, camber and toe numbers near perfect, positive caster for days, and no rubbing. Drives like it did stock! Very happy with this combo! I might do a zero point when I get a chance but other than that I think I’m done with this project!
FS: lightly used uppersYa need some public shaming for thinking uniball anything was a good idea in the first place
I’m on 4th and 30mm rear spacer and it is dialed in. Front is 0.25 lower than rearInstalling 6122/5160 and I have a question... which perch should I set the front to (to fit these tires and be relatively level - little to No rake)? I'm happy to do some molding/plastic cutting, want to stay as low as I can without scrubbing...
- 2013 TLC with 3rd row, otherwise NOT loaded
- Kenda Klever RT 35x10.5x17
- 0.5" Bora spacers available if needed
- Stock Rear springs
- 30mm Rear spring spacer available if needed
Anymore thoughts or comparisons on the dobinson ims set up to the billsteins?
I see a lot of people have kept stock rear springs, but never stock front springs?
Both front struts are height adjustable, if i understand correctly?
Thx
Thanks again, im not super savvy with this stuff yet. I get what you are saying.Fronts are adjustable because the coils fit over the shocks, and the perch on the shock is what makes it adjustable.
Rear is different, where the coil spring is divorced from the shock. The equivalent to perches is to use coil spring spacers that are readily available in 5 mm spring packers or 10mm increment spacers. Even as spacers get a bad rap, they are a totally legitimate way to adjust ride height if you find the coil spring rate is right for load and dynamic performance. It's easy to incorrectly mix the concepts of spring rate, coil free length, and ride height.
Glad you found the Bilstein thread. That's a good one.
My buddy ordered one of the last “full kits” from a major retailer in March and is stilll waiting for his rear right shock. allegedly they will be back in stock at the end of June.Has anyone seen these kits in stock? Couldn't find them anywhere
