I never did get a chance to see your rig. That's quite a beast, Al. Even as tall as you are, I bet you stand up to do oil changes.
Is running the rear 80 diff in the front really that much stronger???
Does it actually fit correctly?
Yes it is bigger and stronger, No it does not fit. The center of the axle housing has to be replaced. Some kinds of american diffs have been used too.
PKP80,
Not to thread jack, but it looks like you cut the inner fender completely out...Am I right? If so what exactly did you do and did you just leave the outer fender edge straight or roll it? Very curious...
37" Toyo's
37" Creepy Crawlers
So did you relocate all the stuff that is mounted to the engine side of the inner fender because there is a lot of stuff mounted there? I could see just losing the outer half of the inner fender, but taking it all would mean relocating some things...and I'm sure you've reageared with 40's? Incredible build though man! Thanks for responding to my questions![]()
Is it possible to fit 37's with no lift? I have a set of 37x12.50R16.5 military retreads that I am sticking on my landcruiser, they are mounted on 16.5x9.75 8lug rockcrawlers with 4.5bs that are going to be attached to the cruiser axles with 2" 6 to 8 lug adapters so the rims will effectively have 2.5" backspaceing. I am planning on cutting the fenders, I know the front will fit since there is ample fender to cut out, but there isn't much in the rear before you get into the door? I want to keep it real low to the ground and spend as little as possible. I know it will have very little uptravel, but I am not going to drive it fast so it doesnt matter. I am going to try it when I get home from work and if it doesn't work I will probally order a 2.5" Heavy or J front heavy rear. Plan on welding the diffs up and setting up a cheap surplus center ram for assist, already have lockout hubs on the front. Got a bunch of 1 3/4 sch 80 pipe for bumbers, sliders and quarter protection.
