big tires
My 37x12.5's have been on the rig for almost four years, it has a tuned OME J setup. IMHO very well matched to the rig and how I use it. Don't foresee changing anything, well other than possibly installing the 5.29 gears that I have owned for about the same number of years!:hillbilly:
Kinda thread jack. Tools, what is your front setup like (and rear)? I would like to eventually run 37s on my LX and would prefer to keep the wheel moldings. Right now I'm Js and Ls all around with 2" Metal Tech spacers in front. 2" Bump stop drop in the rear. What is your wheel backspacing? Thanks...
You should be good with the 2" Metal Tech spacers in front, they also act as bump stop spacers. On the rear, may need to space the bump stops slightly more? Mine are 3", but also have the shock mounts spaced down ~1.5", so have more flex, tire angle at full flex.
In my experience, to get full flex and retain the flares, the tricks are narrow tires and proper wheel spacing, it gets pretty tight with 37's. Between the rim width/backspacing and wheel spacers my tire center line is moved out about 1/2-3/4". If the wheels are spaced out too far the tires hit the flares on straight compression, not enough they contact the frame/wheel wells.
37's with OME heavies front and rear, 2" coil spacers up front. never broken anything. I did manage to strip the teeth off the d/s birf and drive flange one time. I figured it was due to high mileage on the truck and the AWD factor. it had 205k miles on it when it happened.
38,s and wheeled very hard.
Looks just like mine. Its white/no flares and dented in all the same places. ha ha Just different tires/wheels.
Sorry for the thread jack...
Who sells a body lift ??? And what hieghts do they come in ???
I'm just researching the FZJ-80 Cruiser sooo I know what to do with it ... I'm planning on sending one back home to Philippines as a Daily driver thru the Muddy roads that leads to my house in Butuan.
I would like to have 35x12.5x17 or 37x13.5x17 on it but I want to have alot of wheel well clearance as well... Will I have alot of wheel well clearance, if I went with a 6" Slee offroad and maybe a 2" body lift... The roads to my house is pretty muddy and only dirt bikes can go up there when it rains... And it does get really flooded in certain parts...
pls inform me thanx for the info in advance...
that is a big body lift also.
That rig looks great and I love the stance, but I would not want to wheel that thing in anything off camber, narrow, or steep. It sits WAY too high for any quality wheeling IMHO. it looks like 4" body and 8" of lift.
Hi I'm running 38's
Fox shocks Tjm coils 7 inches lift
