big tires
I'm running 37x14.5 Irok's and have broken one birfield.
No, I don't think you are going to get 37's on with no lift. I had 315's on mine with no lift and they rubbed when turning and on bumps. I don't think you can cut enough out of the front of there rear opening due to the door. I went cheap and put on J springs and a body lift to clear the 37's.
Those Irok's look tough. Is this a DD? Do you have any pics on level ground?
37" trxus MT's on a 3.5" FOR Gen II lift.
Drives like a dream, wheels ok, too :D
Haven't broken anything (yet).
I'm not afraid to cut a bitch up, so I am going to try to fit the 37's when I get home and if it doesnt work I will order springs, spacers, or whatever I need to clear . I want this thing super low slung so the heavy fugger doesn't roll over on me. There was a thread on pirate where a guy stuck 38's on an IFS Toyota Truck with no lift so I think I can do it too. I don't need much uptravel this thing isn't going too see much speed and I am going to leave the 4:10's gears cause I plan on stabing a 6.2 diesel in eventually and won't need the extra gear.
I think what you will find is a 3" to 3.5" lift is ideal for 37's. I have a 10" shock travel setup, deliberately not increasing overall travel so the rear does not overly unbalance from the front, and it is 5" up travel and 5" down, which is perfect balance.
I have a little bit of trimming, which I did up front for my bumper and a tiny bit in the rear wheel wells. 1" wheel spacers to keep it from rubbing.
37's on a stock setup likely will not clear the top of the wheel wells on stuff (I barely clear on my lift with 1" wheel spacers), so you'll get into cutting stuff you may not really want to cut. 80's have such huge wheel wells that you can get a little bit of lift and run a really good sized tire. I have really no concerns about rolling my rig that I wouldn't have with basically no lift.
You are going to want gears, I think even with more engine. These things are so heavy, they just need gearing so badly, and the stock gearing is not very low. 5.29's are adequate for 37's.
This is a pretty good video (and is where the second pic above came from) that shows a crawling climb with my gearing. You'll notice two things. The first is :princess: was filming and I was driving like a pansy accordingly, and second is quite a bit of rocking back on the initial climbs. I use my hand throttle quite a bit for consistent throttle in situations like this to compensate for the lack of crawler gears.
Anyway, stock height is too low for these pigs, the frame is so low hanging that it is a real liability in rock gardens.
Going straight to 37's is the right choice, I had thought 35's were the real balance between on and offroad but they are not: 37's are where these pigs really start to shine offroad, and onroad there has been zero difference, both tires fit on a small lift with a bit of tuning for the 37's, both will drive on the highway about the same for a given gear ratio (5.29's are still low for 37's if you want to drive fast).
37's are also where the 80 finally starts to look like it has big tires.
So build around the tires, right way to do it.
:cheers:
Old Chinamans Gulch - The Rock Pile 11-22-09 on Vimeo
Post up progress pics. You have the 3FE now? I ran my 37's on 4.10 gears for a while. SUCKED, but it went down a straight road ok that way. 5.29's brought the grin back when going up a hill. :D It is still a pig but livable.
Cut, cut, cut. :clap:
Speed-
Now that was a real thread jack...:clap:
PKP80-
I'm completely following you man. So you just cut the outer fender in a line following the top of the bolt holes for the flares and then cut out the outer side of the inner fender. Sounds like a plan...now I just need to save up for some 38's. I'm running 851's (actually an ironman equivalent) up front and 862's in the rear with a 1" body lift. Front is 23.5" hub to flare and rear is around 23". I think with the trimming I can make it work.
I spent 4 yrs in LA. Went to dental school at USC and graduated in 2006. It was lots of fun. Now I'm in the Air Force stationed in Guam. I bought my first 80 series here and I'm loving it. Some 13/38 bias ply swampers would pull very nice in the red mud here! Peace out man and thanks for the intel...:beer:
My 37x12.5's have been on the rig for almost four years, it has a tuned OME J setup. IMHO very well matched to the rig and how I use it. Don't foresee changing anything, well other than possibly installing the 5.29 gears that I have owned for about the same number of years!:hillbilly:
i am runing 38.5 boggers on fj40 with 80 axles with e lockers all stock axles snaped rear pinion,but was do to axle wrap and drive shaft bind
I am having way to much time to think while I am out here on the water at work and I don't want to have to wait till the next time I am home if the 37's won't fit with no lift so I think I am going to order some lift springs. So should I go with a full J set or a J front 2.5" heavy rear? I want it to sit pretty level and I hear the J setup stinkbugs pretty bad? I won't be hauling around a bunch of weight either and if I do I could get some air bags for inside the springs. Or should I go J rear and Slee 4" front? What amounts of lift will I be looking at with these spring combo's? Thanks for all your help you guys are the best.
I just came too and found a black credit card in my hand and a order confirmation from Man-a-fre on my screen. I guess I ordered
J springs
30MM Spring spacers for the front
Extened SS brake lines for the front and back
Lockrite for the rear
Nifty little shock adapters so I can use my BBCS shocks on the front probally buy another set for the rear
Hub socket so I can rehabilitate the front end (waiting on marlin seals to stock)
already have
Locking Hubs
2" 6lug to 8lug adapters (so I can use the rims/tires I already have)
16.5x9.75 rockcrawler rims
37x12.50 Retread Hummers (better tread then stock, big open lugs)
scd 80 1.75 pipe for sliders & bumpers
I guess its time to finally give up on my buggy dream and sell the 1tons, airshocks, doubler, ect. I will keep all my .250dom/ballistic joint links for a future 3 link front and rear. I am getting older and need to focus more on family and having stability so I am now a devoted FJ80 guy, hey that kinda feels good. Next is a diesel engine of some kind, probally a GM 6.2 with Marks kit to use the A440.
