BIg Problem? Leaking antifreeze help
Ok, after some limited looking this is what I came up with.
1) Only leaks while vehicle is ON and more when vehicle is warmed up.
2) The leak is more like a stream with some pressure to it.
3) It leaks under the driver area but not in the wheel well. More under the car than to the side. The leak hits the anti roll bar right under the drivers chair.
4) Like I said before, It is not a small drip but def. a pour/ stream that leaks only when the engine is running/idling.
5) The coolant low light came on in the dash.
6) Coolant resovoir looks half full and dark brownish.
Couldn't take pics. I just want to rule out HG/engine rebuild. I can deal with replacing old hoses and crap like that but not rebuilding engines.
Oh, and the car idle is beautifully smooth. No smoke or wierd smell.
I think my knuckles are shot to crap too from the looks of all the grease on the hub. Standard maitenance on 130k miles I guess.
You didn't find the source of the leak? :confused:
You guys are absolutely correct. That was not the coolant light....of course it wasn't, 80's dont have one. I'm lost I NEED to take it to the mechanic asap. I just went outside to turn it back on. This time I let it warm up. Temp was within opperating range and the light I was talking about before (low oil light) never turned on. There was however a HUGE puddle of liquid under my car. More than ever. The car still idles perfectly fine and the temp is normal. No funny noises either. The liquid isn't sludgy enough to be oil. It has the consistncy and color or a diluted coke. This mystery can not be solved by me that's for sure.
I have the feeling that this is going to be a painful experience.
Is the coolant in the overflow tank the same color? If there isn't any coolant in the overflow tank, check the radiator (when it's cool). Dip a paper towel in the radiator, do the same to the puddle under the truck, compare.
You may have to fill the radiator to be able to see the coolant. If so, it's probably coolant on the ground. I wouldn't drive the truck to the mechanic- if you have to take it to someone, have it towed (on a flatbed).
-Spike
The liquid on the floor and in the tank are the same color.
Take it to a trusted mechanic and have them look at it.
If you want to save money you have to be willing to read (FAQs, Search, etc.) and get dirty.
Do not drive it very far. The coolant color indicates mixing of red and green (this leads to sludge in the coolant system and blockage).
I do have to ask, did you find the PHH?
Riley
Haven't been able to take a good look at it during day light hours. Wed. I will have enough time to take a real good look and get dirty if I need to. The mechanic shop is no more than 2 miles from my house so I don't think it should be a problem. The shop works only on Toyota vehicles and I have friends that take thier 80's there for tuninig and fixing.
Be forwarned, folks charge as much as $250 to $300 to change out the PHH. You can get constant torque hose clamps and silicon hose from NAPA for under $15, and with a little research here, have the job done in an hour to hour and a half. Good time for a coolant flush too.
:beer:
Rookie2
The whole car is going to get a tune up, flush of all fluids, any rebuild necessary (diffs, knuckles etc.) and replace all hoses that are in critical areas (PHH for example lol).
I hope that the shop you go to knows what they are doing and that you have deep pockets! I fully understand the overwhelming feeling of attempting repairs, but after a couple of years of reading threads and buying tools, I have a lot more confidence doing it myself.
From what I can gather from your posts, you really do not want to try a repair/PM and add to the problem. Just get it base lined, then go from there.
Please let us know what the final repair list is and the total charges.
Best of luck,
Riley
Anti-freeze has a distinctive "sweet" smell. It is also highly toxic so if the spill is anywhere that animals can get to it then please clean it up immediately.
-B-
I'm hoping the repair list is going to be minimal and my pockets retain some money. A baseline is exactly what I am looking for and then I will prioritize what gets done.
No animals or children around the spill. I cleaned most of it up anyway. Thanks for the heads up.
I'll post the progression as I find out what needs to be done and labor/parts cost.
crossing my fingers.....
Do this...Take it in and get the list from the shop of what they (1) Must be done and (2) what should be done and (3) what could be done but can wait
Get estimates for all of the work and post back up here with the lists and costs for comments.
If the leak truly is the PHH then either buy these (http://www.1fzfephh.com/) or similar quality so you don't have to worry about it for another 100K miles. Yes you can do this yourself but if you don't have the time then pay someone that does, no shame in that.
Once you have the list then you can decide what if any of it you can defer and do yourself to save some $$. Get your parts from Cruiserdan (on vacation till next week though :frown:) and go at it. Otherwise, prepare yourself for an expensive bill - I'd guess for what you listed above the estimate for all of it to be in the $2500 range, if not more.
BTW, here is a great thread (one of many) on the PHH with pics showing where it is and what it looks like and pretty much why it is called the PHH. PHH & Starter Contacts
Well, I took a better look. I must say it doesn't look good. I found the PHH and it looked intact. I did see a steady stream of coolant/oil gushing between two metal surfaces next to the PHH. I don't know what that is but it looks like some sort of gaket failure....it wasn't coming out of the PHH.
Let' see if I have this correct. The PHH goes connected to the nipple all the way to the right, correct? The leak is coming out from the hole above the PHH and to the left a little bit.
Isn't there supposed to be a manifold bolt in that hole?
-Spike
It's not coming out of the hole where the bolt goes, rather the bigger hole. There must be a gasket there thats blown. The hole directly above the PHH nipple. The liquid is coming out of that area just a little more to the left of the PHH nipple.
Miami.....anyone in Miami that wants to take a look, come on down.
I would be willing to bet the coolant isn't coming out of the intake port, which is the big-ass hole directly over the PHH nipple in the pic (which is the metal nipple on the lower right). It's probably coming out of a hole in the PHH and spraying up onto the intake manifold. At least, I hope it is. Either that or it's coming out from above the intake and dribbling around it.
-Spike
