BIg Problem? Leaking antifreeze help
It's at the shop and hopefully I'll have some professional insight by tomorrow.
I'll keep it posted.
Did anyone mention not to drive it to the shop? That much of a leak is enough to cause a rapid overheat, and premature engine death. Usually it's just a hose leaking which can be easily fixed. The PHH is a PIA, but still is just a hose that can be fixed.
An overheat can immediately cook the head gasket, warp the head and ruin the engine. In that worst case, the fix will cost more than the truck is worth.
So, no driving that truck, and get someone with some know how to look at it carefully. My money is on the PHH.
Also, the temp guages in these trucks are not very responsive. They tend to stay put in the middle of normal range, then jump into hot very quickly.
I drove it to the shop which is about 2 miles away at most. The car ran fine and the temp gauge was normal (slightly less than half way). The mechanic looked at the car for a second at the shop and then he drove me back home and took the car back to the shop...lol. He said he checked the temp at the shop when he got back and it was fine. Tomorrow I should have an update as to what the problems are. I told him more or less what I had found wrong and he said he would inspect the whole thing.
The good news......Not HG
Not so good news:
To replace all that needs replacing costs a good chunk of change
Coolant leak is caused by leaky pump and hoses. Not HG or other engine failure.
He said he is going to replace all coolant hoses (including PHH). Radiator flush and refill.
5hr labor + parts=$550
Knuckle rebuild is about $550 (not necessary at this point but it is starting to leak grease; no noise)
Rear brake job (rear driver side is almost 100% looked up, wont move)
parts and labor+system flush $620
Regular tune up with parts etc. 200-300$ (includes diff oil, tranny oil)
Seems pricey but I'm not really sure what typical rates are for LC
You can save money by doing it yourself. Just start reading. Address the coolant system first. If the rear brakes are locked up, take care of this immediately! What pump is leaking? I do not see the price for a pump replacement.
The knuckle rebuild price is for just one side?
All prices sound typical for an independent shop. If you can afford it, let them do it if you are uncomfortable doing it yourself or you need the vehicle right now.
You can save money, but like mentioned before, you must read and be willing to get dirty.
We can help you with all of this, but only with major commitment on your side.
Riley
The mechanic also said he ran a pressure test on the enigine and it was perfect. He was actually quite pleased and praised the condition of the engine. He major concern were the coolant hoses and the cooling system. I told him to go ahead with the cooling system, brakes and some belts that he said would be better to replace now rather than risk failure.
I'm looking at ballpark $1000 job.....not toooo bad for 137k miles.
I would try to do it myself but I simply don't have the time, tools or know-how. Thanks for the support though....:cheers:
If that knuckle rebuild includes both sides, and all seals, jump on it.
-Spike
-Spike
x2...Typical quote is $1200+ from a dealership but then again it depends on if they do it right or not.
Will be interesting to hear what your mechanic thinks of the PHH after he replaces it :D...5 hrs seems kind of low for what he is proposing with the PHH in there...
Had the tech worked on Cruisers before?
He used to work at toyota dealer (i know him from there actually) and he really knows LC from what he tells me and from a friend that sends his truck there as well. I just wanted to make sure the labor hours and prices seem correct.
Update: NOT HG!!! Mechanic says the enine is perfect. Very clean inside and out. No vibrations or problems whatsoever. He was impressed with how clean and free of serious mechanical problems the car had.
However, that beeing said it still underwent some serious work:
ALL Coolant hoses replaced (PHH included)
ALL Fluids flushed and replaced with oem fluid (3diffs, engine oil, coolant flushed twice, brakes flushed)
Complete rear brake job
Front Driver side Knuckle rebuild (seals etc..) plus adjusted all diff lock actuators.
Thermostat, spark plugs, wires, cap, air filter replaced
A painfull $2200. This is also the first major service and at 130k miles thats not bad at all.
mods will have to wait.....:doh:
Glad engine is in good shape. For all of the work they performed, the price is not that bad.
Also, if a $110K+ Porsche 997 Twin Turbo is a toy to you, a measly $2,200.00 is a drop in the bucket! Let's see some pictures of that!
Riley
I'll try to post pics of both autos as soon as I have some time.....it's a busy life when you have toys like these. Busy working or busy playing but busy nonetheless :D
I thought the mechanic charged a fair price for the amount of labor involved. The brake parts were expensive, like 600$ just for the rear.
I think the culprit hose was one of the coolant hoses near the PHH. I think he mentioned something like a Y piece or junction piece.
I thought I would add this question for you guys:
Tire size w/ stock suspension
I want either 285/75/16 or 295/75/16 Nitto Terra Grapplers
I would go with the 285 but they aren't a true 33" (32.6) whereas the 295 are 33.2"
what would you go with if you were in my shoes?
I was also looking at Dick Cepek FCII....any good? They look decent
I have been quite pleased with my Toyo's. Great tire and bullet proof.
Buck Buchanan
One comment and one question. It doesn't make a lot of sense to only do the driver side knuckle but I guess that is what you got and it would hold down the price a little.
The question is.... what did he say he did to adjust the diff lock actuators? That is a new one.
-B-
He hasn't done the diff yet but he was going to take a look at if wed. Basically he is going to check that they lock and stay locked. If anything needs fixing and adjusting he will fix or adjust accordingly. Actuators was a word I used, not the mechanic. I didn't have a better way of saying it. Apparently some lockers tend to unlock themselves at times???? Not really sure?
What should I be looking for?
CruiserRx- next time you talk to your mechanic, would you mind asking him what exactly was leaking and report it back here? Would be appreciated.
Assuming you have the factory F&R locking diffs, the only issues that are reported with any frequency are "slow to lock" and "won't lock." I don't believe I have ever heard of anyone that said they had a problem with theirs coming unlocked inappropriately.
The "slow to lock" is almost always a matter of lack of use. Basically the 10-15 year old grease gets sticky from never having the mechanism used. Most are able to fix this by regularly exercising the lockers. Some (a few) have had to tear into the assembly and clean them up.
The "won't lock" problems are frequently due to a sensor; center, rear, and front in likelihood of being a problem. There isn't anything to adjust though you can try removing and cleaning the sensors.
I have heard of 1 or 2 where they couldn't get them to unlock. This could be due to damage of the axle splines or the wiring or the mechanism. I don't recall the details but this is fairly rare.
-B-
