BIg Problem? Leaking antifreeze help
I've noticed a relatrively large leak coming from the fron of the car and it seems to be antifreeze. Its a significant leak not a slow drip.
What can it be? I'm new to to land cruisers and I really hope it isn't a cracked block/HG or something like that.
Like I said, it's a large flow leak, not a drip. It seems to be leaking from the drivers side of the engine. Car idles fine and starts up with out fuss. No smoke or unusual odors.
My advice is to get under the Cruiser with a bright flashlight and try to trace where the leak looks like it's coming from. More than likely it's a leaky hose. Just check every hose, if that ain't it, you may have a leaky heagasket or worse. Don't be afraid to get dirty. Take pics if you aren't sure what's up.
TK
Check your PHH!
Riley
x2 especially if the leak is near the tire on the driver's side. Can you be more descriptive of where the leak is coming from? Front of engine, rear of engine? Pics would help as well :cheers:
What's PHH? Def. newb question.:flipoff2:
I'll have to check the EXACT location when I get home later tonight.
If it's a big-ish leak is it usually the PHH or is it more likely HG related?
Mid engine with most of the leak on drivers side. Def. not a trickle or slow drip leak.
Wow, we should just start simple as noted above. Get under the vehicle with a good light and find the leak source. Report back on the general location of the leak.
We can school you on what a PHH is after that (or hit the FAQs & search).
Riley
edit: Look here for info: http://www.sleeoffroad.com/technical/tz_heater_hose.htm
Pesky Heater Hose. It's about a 2 1/2" long piece of hose that comes out of the side of the engine and ties into the heater down pipe. Kind of hard to find, unless it's leaking :flipoff2:. Just follow the trail.
PHH. If you had a cracked block, it'd be running rough and spewing smoke. About 100% it's a hose, and about 99% it's the PHH.
:beer:
Rookie2
Thanks for the detail. I'll try my best to lacate the hose tonight. I hope its the PHH and not the HG or engine block.
'95 with 137,000 miles
Does it leak more when you shut it off and it sits...or does it leak all the time (running, not running, moving, standing still, etc...)?
I had the same problem when I bought my cruiser in June. Turned out the water pump was the culprit for the most part...the gasket was bad and the pump was failing..so it was pouring out where the pump meets the block...then, upon further investigation I also had to replace the bypass hose, the thermostat housing gasket, and the lower radiator hose (those were all leaking as well). Now, all is right with the world. Like others have said, you really need to get under there and see if you can pinpoint where it's coming from.
Ok, after some limited looking this is what I came up with.
1) Only leaks while vehicle is ON and more when vehicle is warmed up.
2) The leak is more like a stream with some pressure to it.
3) It leaks under the driver area but not in the wheel well. More under the car than to the side. The leak hits the anti roll bar right under the drivers chair.
4) Like I said before, It is not a small drip but def. a pour/ stream that leaks only when the engine is running/idling.
5) The coolant low light came on in the dash.
6) Coolant resovoir looks half full and dark brownish.
Couldn't take pics. I just want to rule out HG/engine rebuild. I can deal with replacing old hoses and crap like that but not rebuilding engines.
Oh, and the car idle is beautifully smooth. No smoke or wierd smell.
I think my knuckles are shot to crap too from the looks of all the grease on the hub. Standard maitenance on 130k miles I guess.
How is the engine temp? I would say it's definitely the PHH then from the description of the location you're giving. Do you hear any "scraping" type noise when the engine is running/idling? If not, that means your water pump bearing is fine. If it's the heater hose, have fun with that one ;) Really though, with the info on changing it out on the boards here, I'm sure you'll be fine.
The idle sounds fine to me. No strage hissing or grinding. Temp seems fine but I havent had the car running for long preriods of time so I never really have it at full operating temp. I just took a look at it now and the leak stopped now that the car is off.
That makes sense...definitely the hose (or a hose of some sort). When the coolant isn't flowing through the hoses with the engine off, then it makes sense that it would stop with it off...well, it doesn't sound like an expensive problem which is the good news (hopefully). Keep us posted on what you find out.
Thanks!! for all the info. I'll keep you guys posted as soon as I find out what the mechnic thinks. Prob wed or thurs I'll have some time to take care of it.
This 80 is going to see a decent amount or rebuilding/tuning up in the next couple months. I'll be sure to post my findings, problems and solutions as they arise.
thanks again.
Strange. Your 80 does not have a low coolant light. :D (at least it didn't when it left the factory... me and Photoman have added one but somehow I don't think you have.)
We need pics of the leak and this so-called "low coolant light."
-B-
