I know, I should probably do a search, but how about an updated answer to what are the best brake pads for the money that are out there for my recently acquired 80? I'm still learning, but any help would be appreciated!
from my experience the best has been EBC green stuff pads. I have done the 100 series pads some say are an upgrade but I don't get it. Their bite was not good and I noticed a much better response when I moved to the EBC pads.
The whole deal with 100 series pads is the larger surface area. It's just a bigger pad.
The bite would depend on the compound, wouldn't it? I mean, you could have bought EBC Green Stuff for 100 series.
fwiw i am using 100-series PowerStop Evolution Ceramic. They have to be bedded in with a series of hard stops to heat the pad up (typical for ceramics) but i have no complaints at all, other than the fact that the shims are glued on, making fitment problematic if you are doing new rotors at the same time.
. @98 SNAKE EATER has changed his pads 1000 times. I believe he uses OEM only. I don't think there is a best, all mentioned will get the job done.Anyone else notice the 100 series pads warping the rotors? I never had a problem with warped rotors when I used the 80 pads, but I have now warped my third set of OEM rotors with the 100 series pads. I hated the 12k-15k lifespan of the 80 pads, but since it isn't my DD and changing rotors is much more of a PIA, I am thinking about going back to 80 pads. It has been so long that I can remember if I actually stopped that much better with the 100 pads over the 80 pads.
Smitty
