Berans Hone-O-Drive
Los Altos, CA
Anybody have any leads as to who might work on these? or scanned service manuals? I want to see about resurrecting it. There is references in some old threads to a manual out there but the links are all dis-connected.
This OD has worked flawlessly since 70, now it appears that the syncro has gone out and I cant get it engaged. Without it hitting 60mph is only a dream...
I have it scanned(from years ago) but I cant find it. Seems I happen to be the only person in the world with the manual, yet have never seen a Hone
if I ever find it...will send it your way
WOW......I found it......
email me at
jholmaas@hotmail.com
Anybody have any leads as to who might work on these? or scanned service manuals? I want to see about resurrecting it. There is references in some old threads to a manual out there but the links are all dis-connected. This OD has worked flawlessly since 70, now it appears that the syncro has gone out and I cant get it engaged. Without it hitting 60mph is only a dream...
Looking through the manual - wonder if the brass synchro ring in step 40 is gone, or if a brass synchro ring has worn down out of spec.
The design is similar to a Sturmey-Archer 3 speed bicycle hub. Very, very cool.
I would clean it SUPER well and lube it properly (maybe you have) and give it another spin.
I want one super bad. Quite jealous.
You could just send your transfer case to VV. One could eat cereal out of his.
The design is similar to a Sturmey-Archer 3 speed bicycle hub. Very, very cool. I would clean it SUPER well and lube it properly (maybe you have) and give it another spin. I want one super bad. Quite jealous. You could just send your transfer case to VV. One could eat cereal out of his.
Ha. Thanks. Love to see the inside of a Hone-O-Drive.
You just got to savor those days when the stars align and everything you touch works at the end...
Studied the Hone-O-Drive manual and got an idea how things work, played and adjusted the linkage, changed the fluids (what was left in there) and then rubbed it three times and clicked my heels...by golly I now have the OD back....although there was a little panic when it started to grind and then popped out of DD and got stuck in Neutral at 50mph but nothing wrong with a little adrenaline rush now and then.
Thanks again John (Landpimp) for finding that!
according to the 77 berens catalog you could by the service manual for under 4 bucks those were the days .
I think Marks off road has them for sale .
that's fantastic!
glad someone got good use from the manual
Five years later..... I finally found a decent lead....
I shot a couple of you a pm. I’m going to attempt to put my hone-o-drive on my 1971 fj40. The 3 sp and 4.10 gears don’t allow for fun road trips! More to follow!
Daniel,
I have a mostly complete hone od here and the factory manual. I don’t have the mainshaft and I think the planetary gear is stripped, but good for parts. I’d be happy to send it to you..
Thanks Brian! Let me dig into it and see if I’m missing anything. I did download the pdf provided by Marshall near the top of this thread. But an original manual would be sweet.
