Believe it or not; its still at the Indy Lexus shop. They said the aftermarket globes were bad, I exchanged them for another new set. That was maybe a month ot more ago. I heard nothing so I called, the service advisor said they had to fit it back into the schedule after completing some other work.@Badlarry did you ever get this sorted out?
Did you give then another set of aftermarket globes?Believe it or not; its still at the Indy Lexus shop……. They said the aftermarket globes were bad, I exchanged them for another new set. That was maybe a month ot more ago. I heard nothing so I called, the service advisor said they had to fit it back into the schedule and since that call its been crickets……
Did I miss:Good evening, my fiancee and I have our 03 LX at the local Lexus Indy for a shave and a haircut. They did a rear AC delete, a new exhaust, and they installed 4 new globes which I provided. I went the frugal route (I know-I know) and bought 4 off brand from an ebay seller (good reviews). I’ll attach the report from after they installed them but basically they’re telling me that they believe the precharge in the globes isnt where its supposed to be. I verified that they ruled out all other contributing components, pump, screen, 4 way valve, solenoids, main accumulator, height sensors, and rear springs so we’re not chasing our tail. They verified this and have narrowed it down to the globes. Question here is; can the globes be bench tested for what should be the proper precharge? They’re saying that they cant get the PSIs/Mpa-g where they’re supposed to be. I know just enough about this system to be dangerous but by no means an expert. Thanks in advance. View attachment 4017673
How do you know its not had a sensor lift, by some PO?Excellent write up, thank you for the tutelage. Appreciate that explanation.
“As everyone above has said the accumulators have no affect on the system pressures of a static vehicle. Either the springs are soft/out of adjustment, there's additional weight in the vehicle that needs to be compensated for, it's had a sensor lift in the past or something is physically stopping it from lifting (unlikely).”
Yeah, funny here. No weight in the vehicle, no sensor lift in the past, and nothing stopping it that I could even remotely conceive of. As mentioned before, it could be that the tech ran out of torsion bar adjustment and didnt reindex them, and then possibly defaulted to bad globes? If thats the case then it also begs the question, are the rear springs bad as well?
I’m not super psyched I’m here asking questions but I feel there is a piece of the puzzle missing.
Yes.Did you give then another set of aftermarket globes?
I didnt replace the globes; I provided them in the event they needed them. The ride was classic jarring pogostick. I’m not 100% sure what they’ve done; I havent looked at a service report yet.Did I miss:
Why did you replace globes in the first place. Were you having some ride issue, trying to correct/improve?
Were pressure checking before R&R of the factory/old globes? What were they?
Because its not lifted.How do you know its not had a sensor lift, by some PO?
Very interesting. I’ll see what happens after this next go-round when they get it back in the garage.I have run into issue where pressure keep, changing (going higher). It was electrical faulty. One where a wire housing block (WHB), under DS rear 1/4. Where a group of wires harnesses exit the cabin, to undercarriage. Seems water had been getting in AHC WHB and for years. It became in time, very susceptible to moisture.
It was a difficult to find. As we first found bad hieght sensors. Where ball in arm of sensor(s) frozen/rusted. R&R sensor. I then found air in system, which can also give bad reads and graduations count. Flushed & adjusted all good, for awhile. We'd drive, and all good, for awhile. Then found had to keep adjusting T-bar CW, as pressures keep going up. Due to repeatedly having to CW T-bar, bring pressure in to spec. Ran out of T-bar adjustment/treads. Finale found a WHB that looked curdy inside. Cleaned it up all finally good a stable.
Circle back around. Why did you replace globes?
Giving same aftermarket globes, not best idea.Yes.
Pogostick ride, is likely blown globes. But not always.I didnt replace the globes; I provided them in the event they needed them. The ride was classic jarring pogostick. I’m not 100% sure what they’ve done; I havent looked at a service report yet.
Are you a 100 series expert. That a stated, without facts or detail to support it. Detail how do you know this?Because its not lifted.
So each can be inspected. A blown globe, the cross/top of bladder just inside. Will be a black hole instead of silver cross, or fail pencil easily.
Yeah, well the replacement set is what we’re working with currently.Giving same aftermarket globes, not best idea.
Globes blow, for a few reasons.
Number 1) Pressure to high, for too long.
2- Harsh environment, reduce life.
3-Age. Better than 25 year expected. Even longer, if pressure (Mpa) keep in line in mild climates.
kept even near spec pressure. I've seen 2000 with 450k miles and globes still getting over 8 grads.
I've also seen other reason for pogostick ride. One of those is air in system. Which also can reduce ride height. I just had a case, where I was sure a blown globe. Pull globes to replace, inspecting each as I did. None were blown. All passed pencil test, with plenty of back pressure. Air was in system. Flush and place old globes on, all Mpa good with over 9 grads and good ride.
Do they/you still have the old globes?
Just because it doesn't appear lifted. Doesn't means it not. Position of sensor arms, is telling.
Clear Pictures of sensor, may be revealing.
Yeah, In most cases that's what I find also, "Excessive fluid in globe".Good to know.
I've thought I have noticed in the past that what I was expecting to be a bad globe still had fluid inside unlike the globe I expected to be good and actually reinstalled.
Idk... still doesn't add up to me. I'd confirm their understanding of the AHC system. You're not supposed to see any change in ride height when adjusting the torsion bars. The height sensors control the ride height in the AHC system. One in each front corner and a third on the rear axle.This just in from the shop:
We have adjusted the front torsion bars to a point where the neutral ride height is above spec and the pressures are still too high. We have checked over the rear pressures, the springs are sagging slightly, but not enough to suggest the 3 MPa-g difference from spec.
I’m wondering if these statements could be valid in my situation:
Tightening torsion bars transfers more vehicle weight to the mechanical springs, reducing the load (and pressure) the AHC hydraulics must handle. If they’ve truly cranked enough to exceed stock front hub-to-fender height (~19.5-20” at Neutral, empty vehicle) and pressure hasn’t dropped into spec, the torsion bars themselves are likely fatigued/sagged beyond what the adjusters can compensate for. This is frequent on high-mileage 100-series; the bars lose spring rate over time, forcing AHC to overwork.
Even “slight” sag on original 2003 coils (now 23 years old) commonly causes 2-4 MPa-g excess pressure. Seems the consensus is that coils sag noticeably after 10-15 years, and visual/minor measurement often underestimates it. The shop’s “not enough for 3 MPa-g” claim is questionable—many owners drop 1-3 MPa-g just by installing new OEM or slightly stiffer coils.
I will, just formulating my next message. I’mIdk... still doesn't add up to me. I'd confirm their understanding of the AHC system. You're not supposed to see any change in ride height when adjusting the torsion bars. The height sensors control the ride height in the AHC system. One in each front corner and a third on the rear axle.
^ThisIdk... still doesn't add up to me. I'd confirm their understanding of the AHC system. You're not supposed to see any change in ride height when adjusting the torsion bars. The height sensors control the ride height in the AHC system. One in each front corner and a third on the rear axle.
As @bcarbs said. The AHC systems height sensors control the height. (Tells the AHC rams to put as much pressure is needed to get it to that height)This just in from the shop:
Yes, that's exactly how it works.We have checked over the rear pressures, the springs are sagging slightly, but not enough to suggest the 3 MPa-g difference from spec.
No that's not how it works and I'm starting to think the tech/s don't know WTF they are talking about.If they’ve truly cranked enough to exceed stock front hub-to-fender height (~19.5-20” at Neutral, empty vehicle) and pressure hasn’t dropped into spec, the torsion bars themselves are likely fatigued/sagged beyond what the adjusters can compensate for. This is frequent on high-mileage 100-series; the bars lose spring rate over time, forcing AHC to overwork.
Go ask them what exactly are the pressure numbers. And give them to us.Even “slight” sag on original 2003 coils (now 23 years old) commonly causes 2-4 MPa-g excess pressure. Seems the consensus is that coils sag noticeably after 10-15 years, and visual/minor measurement often underestimates it. The shop’s “not enough for 3 MPa-g” claim is questionable—many owners drop 1-3 MPa-g just by installing new OEM or slightly stiffer coils.
Answer=1 new set of OE Accumulators from Impex. Problems solved....
