bench seat mounting pictures
The West
hey all. i am in the middle of installing the bench seats in the fj40 and was wondering if any of you had any pictures or the back two mounting areas of the stocker bench seat. i need this ASAP for tomorow if anyoen has any pics that would be awsome.
mine is not mountign up properly. it looks like it should fit but it doesn't
i don't have any pictures of this because my truck is in gilroy and im at home tonight..
thanx
rachel
what year is yours ? mine is a 69 seat on a 6/70 body so im pretty sure it should line up.
yes your correct the rear mounting tabs and the area around it pelase. i will check this at like 6:30 in the morning if you can post them that early. thank you very much.
Rachel, I have a 65 FJ40. I had to go into work earlier than I thought. I can get you pics after work, although it sounds like its too late. Sorry.:doh:
thats ok. thanks for trying.
anyone else have maybe a mounting picture of this?
Here is a pic of the passenger side mounting area (top pic) and drivers side (bottom pic). This what you want?
is that bolt running through the floor support beams?
that hole with the bolt in it looks exactly where my seat should mount but there is no hole there. i guess i'd have to drill one. i bet there is bondo blocking it up.
the hole for the seats that is not matching up ( i thought it was the seat hole) is like 2 inches above the seat bolt.
thanx guys for the pics
Rachel,
Here are some more pics. The bolts screw into captured nuts that are inside the support channel under the cruiser.
