Belt squeels at 60mph.
Trollhole
THC
Supporting Vendor
Moderator
Mauldin, SC
Website
forum.ih8mud.com
Driving home and when I got over 60 the fan belt would start squeeling. I checked the tension and it seem tight. Could I be having a water pump failure. Alternator in 1 month old. I ended up having to use a small belt on the alternator. Since that is what the pully used. And the rest of the pullys on the water pump and crank are the stock larger size. DO you thing this could be causing the issue?
Strange thing is it wouldn't do it in a different gear at the same rpm. :confused:
e-man said:
Buy a new belt.
It is a new belt.
From the comment I take it no one has had this problem so it must be something simple. Will try to tighten belt further and se if it goes away.
If it isn't settling all the way down in the pulley groove, that is, the belt is too WIDE, that could be part of your issue.
Trollhole said:
It is a new belt.
I have this problem, but it's because I have jury-rigged brackets and my alignment is "less than optimal"!
While you're in there, pop the belt off and check that the water pump and alternator turn easily by hand.
Assume your alignment is OK?
Cheap belts sometimes squeal when new.
Poor some Pepsi on it and it should help the squeel. Always worked on Papa's old chevy farm truck. If that doesn't do the trick autozone sells a cream for it. A belt cream.
Sure you're not driving a pig?
Just tighten up a little more and be off.
If you'd keep it below 60, then you'd be fine! I've found 52 is right about where it likes...
What about Coke? RC Cola?
