Beadlock Question
Federal Way, WA
I am starting to save for a set of 36's. I'll probably pick them up towards the end of the year. I have also been reading up on DIY beadlocks and thought I might fab a set to go with the new tires.
Reading info from sites selling the kits it looks like they add about 2" to the width of a rim. I will hunt for a replacement set of rims to build up over the summer, but I am wondering just what width would work best for beadlocks. It might also be a good time to look at the backspacing to help avoid interference with the leaf springs when running larger tires.
I currently run 33x12.5x15's on 15x8 rims and they are perfect. I plan to look for tires 12.5 up to 14.5 wide. Would I be better off with a 7" wide rim? That would put the mounting surface width nearer to 9" with the beadlocks. I am also thinking about using a 2.5" backspace so I get better clearance in the rear wheelwells and so the tires won't hit the springs at full turn.
What are others running?
I run 8 inch wide wheels with bead locks and they are about 9" with them. I would not go any smaller or larger. I run 37 iroks and they are about as good as it gets. Back spacing I believe is 2.5 inches.
See my DIY beadlock thread in my sig for specifics and pics
Good luck
Thanks for the info Cam... Now that you've had them a while, if you started over would you do anything differently?
Nope. Well maybe different valve stems. But no they have been perfect. No leaks or anything. I love when the bolts bite into the rock and give extra traction. That's a bonus you'll get
cam - on the trail, what tire pressure are you running?
3-5 lbs
Depending in what trail. But in Moab for example 3 lbs
My last outing I had a leak, made it back and never popped the bead. Wouldn't even register on the gauge.
