"baseline" question, Newbie needs a schooling
Maine
In my hours of researching this site, I have heard "bringing it up to baseline" mentioned a few times when buying a FJ80. What is that referring too?
Baseline: the data used as a reference with which to compare future observations or results.
The object of the game is to eliminate unknowns that exist due to poor maintenance habits of the previous owner(s); the use of aftermarket parts as opposed to OEM; etc.
Otherwise, back to a reliable truck without anything leaking, squeaking, rusted, busted, corroded or exploded.
Baseline
Change all fluids so you know when they need to be changed in the future
Do Front axle service if you dont know its been done in less than 40K miles or you see sludge on the balls
Potentially rear axle job
Change Spark plugs, PCV Valve and hose
Check brake pads, air filter etc.
Once you feel it is fully caught up, you can consider it baselined and then can schedule PM when its needed knowing its the right period
