Baseline/DIY Amazon List
sleepycruiser
I will get by….I will survive
Asheville, North Carolina
So I am to the point where I need to baseline my LC. Had it a few months and I want to make sure that everything is taken care of. So I searched and found some great threads....
Comprehensive Baselining List
That thread has a lot of good info....but what I want to do in this thread is list the Baseline topics and have links to all of the stuff you will need to complete that task. For my sake, I made the first list for oil changes and will include the links. If anyone else wants to tackle a subject, just put what baseline project it is and then just put links to the fluid you prefer, grease, whatevs. For me and hopefully for others it will help those that get a ton of different threads when they search....and put all of the stuff they will need in one post. We all know there are several different fluids, tools, etc to use....so let's not get into what the BEST vs the WORST is...lets just put a list down and leave it at that. Hopefully this first post isn't the only one of the thread. ;-) If something is missing from someone's post, please QUOTE so that the OP can go back and edit/add info if they need to.
Links don't have to be from Amazon, but if things can be sourced on Amazon that would be helpful as their site is straightforward and you can make LISTS under your account, so you can have an Oil Change List, Differential List, etc.
So the format will be TOPIC, Link to DIY, and then the stuff you will need. Ok? I hope this helps others that are about to tackle things they have never tried before.......
OIL CHANGE:
How To: Number of questions starting with an oil change
Stuff Needed:
Oil (8 quarts)
https://www.amazon.com/Pennzoil-550038340-Mileage-Vehicle-5W-30/dp/B00ELHNIG6/?tag=ihco-20
Oil Filter
https://www.amazon.com/dp/B0044B0YJ8/?tag=ihco-20
Oil Drain Plug Gaskets
https://www.amazon.com/dp/B007OW6MD6/?tag=ihco-20
12mm 6-pt socket
https://www.amazon.com/TEKTON-14117-4-Inch-Shallow-6-Point/dp/B000NPPCGY/?tag=ihco-20
Optional:
Drain Container
https://www.amazon.com/dp/B0171QLC4S/?tag=ihco-20
Latex Gloves
https://www.amazon.com/gp/product/B0013J62NQ/?tag=ihco-20
Funnel
https://www.amazon.com/Lumax-LX-1602-Black-Plastic-Funnel/dp/B000MCZKIS/?tag=ihco-20
Shop Rags
https://www.amazon.com/Auto-Mechanic-Nabob-Wipers-Commercial-Perfect/dp/B01BJJ3F70/?tag=ihco-20
Breaker Bar
https://www.amazon.com/Neiko-00338A-Drive-Premium-Breaker/dp/B009GLIPL0/?tag=ihco-20
Who is getting the reference credit for those links? ih8mud?
You can reduce the link to include no referral if you are just copying from somewhere else.
I am not sure about reference credit. I just copied the link straight from Amazon. I will check on making the link shorter. Thanks.
You might look on eBay also, quite a few dealers are now selling Toyota parts on eBay. I got a case of 10 Toyota oil filters for 39.99 shipped.
True, like the knock sensors, or the TPS sensor for a while. There are exceptions too on Amazon like the Aisin water pump or fan clutch. I guess shop around and be aware of wholesale cost!
