In the last couple weeks, I have seen many requests regarding what it means to "baseline" your truck. Almost always an excellent answer is given by the forum, but it can be hard to track down all the baselining threads. So having just gone through much of the baselining process, I thought I would put together a list of common PM items in one place with corresponding walkthroughs.
FWIW, this list is not meant to be proscriptive. Only you can be the judge of how much preventative maintenance is enough. However, I hope you may find the info in this this thread to be useful - YMMV.
One wise note on baselining -
All OEM items can be had, at very reasonable prices, through CruiserDan right here on the forums:
1-800-432-6668
https://forum.ih8mud.com/**-ih8mud-com-vendor-marketplace-**/17873-getting-cruiserdan.html
Fluids
Motor Oil – Synthetic / Chevron Delo
https://forum.ih8mud.com/80-series-tech/242258-number-questions-starting-oil-change.html
Motor Oil Guide
https://forum.ih8mud.com/80-series-tech/79305-oil-recommendations-discussion-thread-faq.html
Oil Filter – Toyota OEM 90915-20004
Differential Oil – Synthetic 80w-90 / Name brand dino
Transfer Case Oil – Synthetic 80w-90 / Name brand dino
Transmission Oil – Synthetic ATF / Name brand Dex IV
https://forum.ih8mud.com/80-series-tech/19299-transmission-fluid-exchange-writeup.html
Power Steering Fluid – Mobil DTE 24 (highly recommended)
https://forum.ih8mud.com/80-series-tech/78646-how-change-power-steering-fluid.html
Coolant Flush – Toyota Red
https://forum.ih8mud.com/80-series-tech/107438-coolant-flush-process-verification.html
https://forum.ih8mud.com/80-series-tech/14891-cleaned-my-cooling-system-full-scoop.html
Brake fluid
https://forum.ih8mud.com/80-series-tech/14685-brake-fluid-replacement.html
Lube
Grease Knuckles – Any Moly fortified grease
Grease Zerks – Any Lithium name brand grease
https://forum.ih8mud.com/80-series-tech/201098-grease-fittings-97-lx450.html
Typical Wear Items
Pesky Heater Hose (PHH) - Silicone (good one @ index)
Slee - PHH (Toyota 80 Series Land Cruiser)
Air Filter - Washable OEM
3x Drive Belts – OEM
https://forum.ih8mud.com/80-series-tech/185209-changing-your-belts-25-minutes.html
PCV Hose – OEM
https://forum.ih8mud.com/80-series-tech/122133-pcv-valve-replacement.html
PCV Valve & Grommet – OEM
Spark Plugs (copper is fine) – OEM
Spark Plug Wires – OEM
Spark Plug Gaskets – OEM
Cap & Rotor – OEM
Valve Cover Gasket – OEM
https://forum.ih8mud.com/80-series-tech/225855-valve-cover-throttle-body-pm-w-pics.html
Pesky Heater Hose – OEM or Silicone (permanent fix)
https://forum.ih8mud.com/80-series-tech/6994-phh.html
Common "when time allows / as necessary / makes me feel warm and fuzzy inside" items
Brake Pads (80 or 100 series up front, 80 in back) – OEM
Clean Throttle Body
https://forum.ih8mud.com/80-series-tech/220474-how-take-throttle-body-off-cleaning.html
Throttle Body Gasket – OEM
Coolant hoses – OEM
Vacuum hoses - OEM
Thermostat & Gasket - OEM
https://forum.ih8mud.com/80-series-tech/2164-replacing-thermostat.html
Service fan clutch (replace silicone oil w/ 6k or 10k CST)
https://forum.ih8mud.com/79-95-toyota-truck-tech/167678-fan-clutch-service.html
Starter contacts & Plunger – OEM
Starter Motor Contacts
New battery (27F stock, 31M fits)
https://forum.ih8mud.com/80-series-tech/287241-install-success-sears-diehard-platinum-group-31m.html
GL
Someone who rock crawls all day long in their 80 is going to have much different baselining needs than someone who merely DD's their rig for 300K miles than someone who has a mix of the two to someone who only drives their 80 2K a year.
But in the end, everyone who owns an 80 should take into account the great CDan thread on the "cost of ownership" as well as should determine exactly what the needs of their 80 are.
https://forum.ih8mud.com/80-series-tech/124556-should-i-buy-80-costs-ownership.html
The philosophical foundations of one's own OCD should be tempered by their ability to pay for it....
1-800-432-6668
Fluids
Motor Oil Guide
Brake fluid
Lube
Typical Wear Items
PCV Hose – OEM
Cap & Rotor – OEM
Clean Throttle Body
Coolant hoses – OEM
Vacuum hoses - OEM
GL
Thanks for putting that together.
(I just popped my 'MUD posting cherry, hope it was good for you too
):, this is a fantastic thread (but there are so many here to be fair)... I strongly vote for FAQ link!
i wish i never knew.
