That's commitment!I go to hong kong and paris to get away from wife, not a pull a part place.![]()
I boogered up the threads on one of the 4 bolts on the top of the knuckle where the steering arm bolts on. Its just the top couple of threads that wont catch. If I can get it on even a little, I believe the threads will take shape again through the motion of the nut going on.
Any suggestions on fixing threads?
I could be wrong but I think that is a stud so if you can back stud out and tread nut from bottom and work it all the way down...if it has threads the whole stud.
But I am banking that I am wrong...so run to harbor freight to get a cheap tap and die set..and chase the threads.
The hub won't even start to go on the birfield? Look at the splines on the birfield. Make sure none are boogered up. If so, take a file and try to make them work. If the hub works on the other side, that tells me it's likely something wrong with that side birfield's splines.
Shazam. Multiple people can't be wrong, right?!!!
Fixed?
