That's about what I figured. I have never even been in a Tahoe, much less considered buying one. I was curious what the cost difference between putting a chevy drive train into a Toyota vs. building up a truck that came with that drive train.
I have considered the tahoe/suburban route, but it really starts to add up. SAS kits can be found for relatively cheap, but sourcing a good d60 front that doesn't need an overhaul isn't particularly cheap. The rear 10 bolt will also be a weak spot especially if going on the bigger end of the spectrum with tires. So a 14 bolt rear--also not cheap. Rear lift would be easy for a suburban (shackle flip on stock leafs), although I don't think the tahoe suspension is really up to much abuse (stamped steel arms with coils), so fabricating suspension arms and whatnot.
I think if you went with a 2500 suburban, it would probably be the most economical route. Just SAS, and the rest is pretty stout. But then you have to consider the door handles falling off, mirrors shaking loose, and general crappyness that might ensue... but I've got all that crap happening in my 80 too, so I don't see the big deal
I will say, it is absolutely amazing how compact an LS is compared to the big 6. It's like a plus-sized watermelon whereas the F motor is more like a small table.
