Ok, I've been wanting to bag the cruiser for several years now. Seems like firestone and other companies finally getting something reliable out to possible use. There are a lot of reasons for this but I won't go into details just yet. I do wheel it occasionally but not looking to do it for that reason. I've ran across a couple posts here with seemingly no results. I have a mixed mutt lift ( mixed OMEsprings and SLEEspacers) just under 5" with about 60K and going on about 6 years on it and finally considering swapping out at least the rear first, have 35" tires and possibly going bigger rims eventually (18" -20 with toyo mt meats). I have done measurements for the rear for max compression and extension (with sway bar and shock limits). Looking to keep the same max ride height with about 3"- 4" drop for highway and towing with the caster probably set for the low height (probably eventually throw the stock arms back on or go 3 link if and when I finally get to the front).
Anyone here successfully fully bag their cruiser with good results or know someone who has? Have a good vendor for quality valves, tanks, spring mounts for axle or frame or components or knowledge with springs who can recommend a good fit? Preferably in Colorado but not a must. I'm not necessary looking for a system since I plan on doing it in phases because of the issues you run into up front. I know there is a company in OZ supposedly with a kit for the 80 and Kelderman with many applications.
I have placed a Michelin compressor in the PS rear storage area and piped it to my current helper bags with a accessory fitting under the gas cap for airing up miscellaneous items, piping with 1/4 hose for now. Check valve and 1 or 2 tanks coming next where the spare tire once sat under the rear. I will eventually add another compressor behind the same panel below the speaker for reliability and more air flow to the tanks.
Got a link?
