Bad Turkey? Sequioa vs 80
North Front Range, CO
I think I may of had some bad turkey as I found my self in Denver last Saturday night test driving a 2002 Sequoia:eek: and worst of all, I LIKED IT:doh:
I have seen may 80 vs (what ever) but not the Sequoia.
So let the leaves fall, can a Sequoia which is longer, taller, wider and maybe heaver do what a 80 can...i guess not but it is shorter than a double cab Taco and has loads of more power. Add in, little to no after market off-road parts, no lockers and only about 3" lift.
Other than that, could the big tree :princess: keep up with an 80?....never mind.
Anyhow, I liked it and it is on my 300,000 mi 80 replacement list.
They are nice trucks and 100% road oriented - much to like.
They compare excellently to an 80 for the SUV market, but for a road SUV they don't tow well so you are basically talking about a minivan without the cargo or interior space of a minivan and with much worse gas mileage.
I'd much rather have an 80 and a pimped out minivan than a Sequoia or a 100 or a 200, and come to think of it, I do :flipoff2:
<<<sequoia's are too high maintenance>>>
How could anything be more high $$$ maintenance than a 80
question: What could be more high $$$ maintenance than a 80???
answer: A Supra.
Oh great, I own both:eek:
Care to define "high maintenance"?
I would think an 80 would be harder to maintain than a Sequoia
simple, in a word "construction"
also think $$$ for the lighter duty parts ;) ...labor...
see theres simple "cave man" HD type sh** and then theres complicated "what the buyer wants" usually lots of switches, sensors the profuse use of aluminum ...tway cylinder heads are not the same as uno...timing belts? chains? I dont know or care how that PT 4WD works....
2 words independent supension
I still don't see how this makes it higher maintenance :confused:
What I do see are thousands of worryfree soccermoms driving Sequoia's without a care in the world :cool:
Then I come here and see head gaskets, Birf soup, bloody PHH, damn sunroof drains, MPG hell, etc., etc., etc. :o
Not saying the Sequoia is a better vehicle (far from it), but higher maintenance than an 80?
All the same has been said about the 60 from the 40 group, same for the 80 and 100 and we all know that the 60 80 and 100 do quite well off road.
Time will only tell about the big tree.
The only limiting factor for all the above was $$$$$. As the price goes down to the point where it doesn't mater if you hit a rock/tree you will see more "newer" SUV's off road, this is when we will see if they make it or break it off road.
well, i'm not here to argue, a sequioa is so expensive to run at over $2 american a litre over here, they throw bearings quite alot and head gaskets is quite common maintanance on most vehicles today, I think they are rack and pinion too that makes the sequioa even more high maintanance
I forgot you have a diesel lol
We yanks only WISH our 80's were diesel :doh:
Sad fact is our gassers get far worse mileage than the larger Sequoias :frown:
I have yet to hear of any spinning bearings and I've only had to do head gaskets on one V8 Toyota and that was a Tundra with over 300k hard miles on the clock :cool:
Rack and pinion may be a weak link, but I have yet to see any failures common enough to call it high maintenance...
