Bad Engine? What to do now.....
Hi. I'm new to this forum. It was recommended to me by somebody who used to have a cruiser and visited this forum. Anyway, here's the scoop.
Recently purchase a 97 Land Cruiser with 81k on it. Had it checked out before hand at a local dealer. Had them run a compression test just to be on the safe side, even though they thought it looked well taken care of and did not need it. Compression was consistant accross all cylinders (approx 170 + or -).
Now, I've had it about 10k miles. It's using a lot of oil (approx 1at every 1200 miles). I'm running dino 10-30, although from reading this forum it looks like I could be running anything from 0-30 to 15-40. I can not find any leaks. It does not 'smoke' at start up. Gets mostly city driving (probably 80-90%). I have change the oil 3 times (at purchase and every 5k after that). I changed the PCV Valve about 4k miles ago thinking that would aleviate most of the problem. It did not. PCV Valve was not "sticking" shen I took out the old one. So much for the $5 fix.
So, any thoughts? I'm thinking the rings are bad, but I hope I'm wrong. I'm taking it in Monday to have a Wet/Dry compression test. I'm afraid it will reveal what I don't want it to, which is that the compression improves in the wet test. That will confirm the bad rings, right?
I welcome an and all thoughts, as I'm pretty ticked about this. Really tried to do my homeork and buy the right vehicle, but it seems like I got a bit of a lemon. I'm just not sure what to do now......
Thanks in advance!
Bill
You might ought to get someone you know follow you when the truck is hot and see if they can see anything. Do a pretty quick acceleration run and then let it decelerate. See if any smoke happens then. It's too hard to tell when your driving and looking at the same time. You'll see it driving if it's bad enough. Also, make sure you have the correct PCV valve. If it's not OEM and it's whatever the parts store sold you then it could be sucking the oil out of the motor.
Bill, Congrats on finding a low mileage 97 80, and Welcome!
The engine you have is not generally prone to high oil consumption at that low a mileage.
Replace the PCV valve just for grins, hose too. Fill it with oil and drive it for 1200 miles and check the oil. Then come back and see us.
D
Hello again!
I've followed behind a friend driving the cruiser already with varying speeds and such, with no visible burning of the oil. Also checked many times at startup. I was thinking those two situations might tell me it's the valve guide seals (not even sure if that would be right), but I couldn't see any burning at all.
I have already changed the PCV Valve and hose, both with Toyota parts purchased from the local dealer.
Any other thoughts? I'm really hoping that I'm not looking at a several thousand dollar rebuild here.......but I'm running out of problems it could be. Argh!
How are your driving? This engine is notorious for using oil at that rate when it run hard or on long highway trips. Before you spend any money, try a different oil, preferably the Shell Rotella T Synth 5w-40 and see what happens. Assuming you aren't fouling plugs, there is nothing to be alarmed about by this level of consumption, it is considered in the normal range.
Toyota considers anything up to 1 quart per 1,000 miles to be "normal".
A qt of oil every 1k miles is cheap, and if it's not dripping all over your driveway, I would just live with it. Really not that unusual, except it has pretty low miles. My 93 probably used a similar amount, never had any issues.
You could pull the spark plugs and see if theres any oil fouling going on. I forgot to mention on the earlier post that synthetic oil doesn't smoke as easy as conventional oil. It takes alot tosee on synthetic.
i've already changed the plugs and did not notice them being fouled when I did.
I'm running conventional oil already.
Btw, I should say that I REALLY appreciate any help/input that any of you have already given or may give in future posts. This sure seems like a great resource!
I thought I had the same consumption issues, then I had my oil sampled by Blackstone, and it had a bunch of fuel in it, >3%. I think what was going on was that I would run around town, using a little bit of oil, but it would get no change on the dipstick as it was being replaced with fuel from a leaking injector. Then on the weekend when i would hook up the boat, it would seem like I was burning a quart or sometimes two in 500 miles as the fuel evaporated from the oil. Now I make sure to run to full operating temp for at least twenty minutes a week, and the oil consumption is stable at 1 qt per 1500 miles. I would recommend you have your oils sampled, Blackstone does an excellent analysis of your wear metals, they'll tell you if the lower end is on it's way out. Also, check out some of the recent threads on pcv catch cans, a lot of oil gets past a working pcv valve.
Bill,
If your oil consumption stays in this area then you certainly do not want to rebuild that engine. Mine has twice your mileage and started a similar oil consumption when I switched from 5w30 M1 to 0w40 M1. My consumption is still higher than I would like but a heavier weight synthetic is helping.
You may also have an oil leak that isn't hitting the ground.
-B-
