BRH31896 is your PN for the axle to eliminator plate, dual female end hose, like what is pictured above.
I’m in the same boat right now. I actually have the backing plate eliminator installed. But boy it’s too close to my rotor for comfort. So. I’m going to cut out the center section of the backing plates I have to shim my rotor out just a bit more for clearance. Now mouth g that new braided stainless line , again I either have to shave down the mounting tab on the axle (which I prefer NOT to do) or shave down the new brake line so I can get a U clip like your holding to properly secure my brake line. Interested in your fix. I may follow suit.View attachment 4218537
I'm assuming this is how it is suppose to work? (U clip is upside down) The metal is too think for the U clip to fit or the metal female fitting it too short.
Options:
1. Grind down the metal
2. Cut the middle lip flush with the female fitting so it can fit deeper into the metal
3. Find a new hose
4. Don't worry about fixing the rubber fitting to the metal bracket and let the steel brake hose and the rubber hose sit inside the metal bracket without being secured.
Hey guys. What exact brake caliper is this? Where can I get a set? And what year range is this product for? I’ve been trying to find replacement calipers that HAVE WIDE mouths for the vented rotors to fit. These new 19-826 and 19-827 from advanced auto have been modified by the manufacturer to fit only solid rotors. Even though I’m 2000 I bought an exact set for vented rotors. Thought it’d be simple to get replacements. It is not.We've had great luck with the backing plate eliminator with the line tab. We stock hard lines and hoses to fit them as well.
Backing Plate Eliminator Kit - Fits 1958 - 1997 4x/5x/6x/7x/8x Series & 1979 - 1985 Mini Truck Applications (FAXTBPELIMLR)
Toyota Land Cruiser Backing Plate Eliminator Kitcruiserteq.com
Okay. So this is what I just did. My passenger side backing plate was toast. I cut n grinded and sanded it down. Should fix my spacing issue with the rotor. Still need to figure out my brake line.View attachment 4218538
Picture above:
Old hose on left no middle lip sits further into the metal bracket but too short and has a male and female fitting. Need female and female fitting.
Picture above:
The fitting is too short. Trying to sit the middle groove on one side of the bracket to show the U clip groover will not be usable
I know this is an old post but . . .
1974 Fj40 putting on the backing plate eliminator kit from Cruiser Out fitters.
I maybe missing something but the eliminator backing plate metal is to thick for the rubber brake hose line to engage the U clip. The groove for the U clip does not stick out of the metal. As far as I can tell the picture below shows no U clip and the groove sticking above the metal. Unless I'm missing somthing?
So what year rotors are you using? I’m using these Duralast 3237 vented (1981 through 1990 Toyota Land Cruiser ) they were exact match to my old conversion rotors we did in 1996. When you get your calipers show a pic of themSorry to hear that.
I have fj60 knuckles and rotors and I'm going to try to use 1995ish 4 runner calipers. I had to get 1/4 inch spacer for the rims to not rub on the caliper. Will see if they work before I grind the calipers. My rotors don't rub but I did have to hammer back the top of the eliminator bracket where the brake lines attach because the bend was not enough and the rotors would catch on that part of the eliminator bracket.
You can trim the factory shield to reuse it and get a rubber brake line that goes straight into the caliper. Part numbers are posted here on mud for the long and short hose option.
No need for the little hard line still going into the caliper.
Trimmed backing plate. New rubber hose into caliper easy ,very old pick knuckle has been rebuild and running high steer now lol. Pick from 2010
I will dremel as suggested and see how that works.You can trim the factory shield to reuse it and get a rubber brake line that goes straight into the caliper. Part numbers are posted here on mud for the long and short hose option.
I marked it and used a drill stepper bit to go one step bigger. The Dremel wasn't really working as good.I will dremel as suggested and see how that works.
If that doesn't work I may have to get a rubber brake line that goes straight to the caliper and zip tie it to the LROR bracket
