back up parts?
sittin on the couch in UT
what would be the ultimate spare parts you would take on a trail? ie spare drive shafts. fan belts etc :cheers:
Birfs, belts, hoses (inculding fuel rubber fuel line), at least one hub, maybe axles, maybe not... HiLift service kit if you have a HiLift.
Make sure you take zip ties, duct tape, and hose clamps, fluids that you may need and grease.
Oh, and surgical gloves (keeps your hands clean when repairing something, that way the wife wont make you 646 later by yourself)
I would add bailing wire and a cheater. Both can come in super handy. Not as much a spare, but I always carry enough oil to do a complete change. A collapsable jack stand is a good idea too.
I saw a J*%p on Jenny Creek trail this past weekend with a busted out shackle, might be good to carry just one on the trail.
I have to admit though, Nolen G. got me thinking about weight, and how much harder your rig has to work to carry a few hundred extra pounds in spares and tools, I guess it all depends on how self suffiecient you need to be.
I am interested to hear what people think.
Rezarf <><
i take all the above plus, rear d shaft/u-joints, fuel pump, spark plugs/wires. guts for dizzy, fuses, wire/asst. crimp ends, rad repair stuff both the over counter and propane torch/ solder, battery welding set-up, tie rod and ends, brake hoses and generic hard line, main leaf for f/r packs, lots of toyota bolts/nuts, plus all the stuff to make the repairs and things i am forgeting.
alot of this stuff gets carried in the trailer on longer w/e-camping trips and serves as a "base camp" so its close. i have a pretty basic "kit" that resides in a couple large ammo boxes in the rig at all times, it is mostly basic tools, basic repair(cooling,fuel,spark), recovery and survival gear.
I carry shafts for all 4 corners a pinion and a set of spider gears in case one my lockers takes a sh#t, thats it
I also bring a set of points for my distributor. Weight is hard on SF axles. I couldn't amagin carrying everthing that could fail mechanically, you would just end up draggin another cruiser along with you.
if I screw up my rear shaft I can use my front in back, (square) I might make a spare rear shaft sometime. I have also thought about carring a spare nose cone for my tcase, and prolly have a spare knuckle
