Axle seals
Hiding
Does anyone happen to have the part # / info on rear axle seals?
I am rebuilding a set, and need a pinion seal as it is leaky. Can I get these at napa or should I go OEM?
Also what have you guys used to clean out old gear oil. in the third, The stuff in there is pretty mungy and I want to clean it out. Straight degreaser or parts washer?
Also as far as axle seals it appers one may be leaky the other looks fine.
would you replace both or just the one.
how many bananas is this job. Anything to look out for? I have replaced a few seals in my time on fords.. Is the haynes manual any help?
Thanks as always.
I bought diff parts from Kurt at CruiserOutfitters. He won't steer you wrong. If you want OEM contact CruiserDan. Both are members here. But I wouldn't hesitate to use NAPA seals if I needed them quick.
Easy job. Replace both axle seals. :)
do both seals and IMOP do the bearings at the same time
I saw napa had them for like 10 bucks or so each. Any trick to setting them properly. If I remember from the other ones, the guy used a large socket (same rough size as the seal) and set them in that way with a few taps. Im sure the haynes manual has a more technical write up.
i just bought some from sor for mine didnt use them and dont know if the will work for you but if you wnat them pm me
nuclearlemon said:
my 45 used 90311-47001, but on the rears, there may be a difference between the 1960's and later models.
I just checked my garage and the 1984's use the same part #. As I recall, they are $6 each from CDan.
You're pretty much on target, Warren. Coat the seal lips with grease then drive in square with a socket. A block of wood doesn't work too well on the pinion seal as there is a lip that sticks out from the face of the seal (at least on the OEM seals I have...) but would be fine for the axle seals. I would buy the pinion seals from Toyota but the axle seals from NAPA should be fine. Also be sure to clean all the dirt and rust from the pinion flange. Put a little of your favorite gasket sealer on the splines of the flange as well to keep the oil from leaking out through the splines.
HTH,
Nick Jennings
Thanks everyone for the help. This thing is starting to take shape. I love the smell of gear oil in the morning.
FWIW, Napa had the rear diff for 11.49. Aftermarket, and would have to order it 5 states away.
Toyota dealer here had OEM for 6.57. in stock.
Rear seals for the 1977 axle are PN 90311-47001 and they were 6.66 a piece.
Thanks to everyone. Off to Dealer to get the pinion done this weekend.
Warren.
