Axle rebuild questions
The Last Best Place
I have a set of elocker axles in my garage that I plan on swapping into my 97. They were out of a 96 I think and I think the mileage on them was in the 220k range. Not knowing the history,
1. Would you run them as is or rebuild?
2. If a rebuild, what parts would you recommend?
3. If I'm mistaken in the year does that matter being 80 series axles?
4. Is painting them worth it?
5. If so, for a home diy paint job, what would be the best way?
Thanks!
Thanks!
I'm in the process of rebuilding a full float 40 rear at the moment. It was pretty rusty so I'm changing out every nut and bolt along with sand blasting everything and then using Por15 for paint. Doing everything at home myself.
How bad do they look? Have any photos of them? If the brakes are good and the paint just needs touch up I would run it as is. I would recommend @beno for parts. He will give you an honest answer of what you will need.
What is the condition of the axles? Have seen really nice ones that we basically just installed, one set took a bunch of work before installing.
1. rebuild, if you plan to use them for a long time
2. full knuckle rebuild kit plus hub bearings for both axles. Decide on replace/switch sides of birf once you get them apart and see what they look like (this question is covered literally hundreds of times on this forum)
3. Doesn't matter, e-lockers are all the same. There are some 96-97 year model wiring differences (I know for a fact that cruise control and power antenna are different) but IIRC this doesn't include the lockers
4. depends on how bad they are
5. pick your poison
They are mainly dirty, not rusty like some. Didn't come with brakes.
Add wheels/tires and wash/degrease them. Adding the wheels makes it easier to move them around. Degrease with ZEP or something similar, use a toilet brush or other long-handled nylon brush to scrub them really good. Spot repair the rust, spray with Rustoleum tractor paint (or your paint of choice).
Then take them apart, clean and regrease the stuff inside, replace all the rubber parts and the tie-rod ends.
Replace all of the studs(they're not expensive).
When you re-assemble everything, wipe off any grease from the rebuiild process and spray with your paint again. Good as new.
You'll like this: I have a '95 with a weeping rear main. The underside of the truck looks like it did when it left Japan. Under no circumstances consider degreasing any forged or cast parts. Unless you are prepared to bake them under heat lamps for a week to remove all the imbedded oil, they're better off oiled; it's permanent rust preventative. Then you have to prime and paint them or you'll lose them to rust.
(I used to rebuild machine tools. They sit in cutting fluid and oil all day, every day, for decades before anyone considers rebuilding them. Repainting them took exactly this process. It added 10-20% to the rebuild price, which was always north of way expensive.)
I also built axles for a major automotive supplier. You only need to check the gears for wear. If the backlash is within limits, you're good. If not, you have to rebuild. It's that simple. Replacing bearings and seals will be easier now than when the axle's installed. Do it now; it's cheap insurance.
I don't know for certain, but I think Toyota offered two different gear ratios in the '95-'97 model years (collector's and 40th editions?). Someone please correct me if I'm wrong about that. If that's the case, check the ratios and make sure you have a match.
Happy motoring!
^ all same ratio
Looking at your picture that one front knuckle in view looks wet with grease. So I'd rebuild the knuckles and replace all the bearings/seals in both. At 220K it's hard to know what condition n the birfs are in until you put a load on them. That's when I replaced mine but mine had a much harder life than a stock rig for the same miles.
Check the backlash but I'd wager the gears are just fine.
Have pressure washed, degreased, and painted a bunch of Toyota axles without issue.
So, bearing preload is irrelevant?:confused:
Happy motoring!
The NA axles are the same ratio.
For the benefit of anyone reading/following this thread,
My commentary on painting is based on my industry experience with passenger and commercial/industrial axles, and industrial equipment. You results may vary, but I can reiterate what I have seen personally, and what has been expressed to me by coating industry experts: no paint will adhere properly to any substrate, especially metal, which is not clean, dry and grease/oil free. It may temporarily adhere, but the coating adhesion lifetime (especially for modern water-based paints) is negatively impacted by contaminants, especially, those which are hydrocarbon based. Cast and forged steel is extremely porous, and susceptible to full-depth contamination by grease and oil. The bond between the steel and grease/oil is very strong (for the same reason you can’t get food grease out of your wife’s Tupperware). Superficial degreasing or washing only serves to wick the deeper penetrants to the surface; the time to do this varies by contaminant level, environmental conditions and the presence/thickness of any superficial coatings.
@Tools R Us is absolutely correct that the preload on the bearings supporting the pinion and ring gears are vital to proper operation of the gearset. For the benefit of those who may not be familiar with spiral bevel gear design and operation in passenger vehicles, this simply means that the bearings which support the pinion (driver) and ring (driven) gears, which are of a type known as angular contact bearings, must be pressed together with a sufficient pressure which will ensure the internal tapered rollers contact both the inner race (cone) and outer race (cup) so as to provide full support to the gears. This is unique to this type of bearing design; ball and needle bearings do not require preload, since they are designed to support single directional loads.
This is accomplished on the assembly line by the inclusion of spacers (or shims, depending on who you talk to), under the bearings, adjusting preload nuts, or both. Since directly measuring the amount of force compressing the bearing components together is impractical (it would require a load cell under the bearing, for which there is no room in the production component design), the preload is measured using the solid, unloaded height of the assembled bearing, and the bearing manufacturer’s recommended installed (compressed) height.
The result of this is that the spiral bevel gear teeth are pushed together and a sufficient contact area is achieved which allows the gear tooth to support the load which is placed on it (them actually, since two teeth are always designed to share a load) during operation. The primary mode of failure for these types of gearsets is fatigue, and the primary source of that fatigue is insufficient contact area. On the assembly lines, this is measured by either measuring the backlash (the distance between a tooth on one gear and the combined clearance with the teeth in front of and behind on the mating gear), or by printing the contact area, usually with white lithium grease. Measuring is faster on the assembly line (but requires special equipment/setups), but printing is the only way to positively verify contact area.
You can’t have proper tooth contact without proper bearing preload, but preload alone doesn’t guarantee proper backlash (the gears are also provided with setup spacers/shims), which is why this is the first check for correct gearset setup.
Thanks for the input everyone. What are the differences in wiper seals from different vendors?
