Axle rebuild question
Iowa
I am getting ready to start working on the axle rebuild for my 95 and I ran across a couple of things I had questions on.
Is it better to use the OEM wiper setup or change over to the Trail Safe Knuckle Wipers or the Longfield Wipers? Also, if the Longfield wipers are better, is there a source to purchase them?
Also, I got the rebuild kit from Cruiser Outfitters with the OEM axle seals. Would the trail safe axle seals be a better option?
Just want to make sure I do this right the first time!!
Thanks in advance?
Whereas I too prefer stock OEM parts - I went with the Marlin Crawler EcoSeal inner axle seal.
HD Inner Axle Seal | Marlin Crawler, Inc.
As our vehicles age - I thought this made for an excellent upgrade!
X2
consensus over the years is that the Marlin inner axle seals work better on part-time 4x4 rigs, and OEM better on AWD
Just installed the trail gear wiper seal kit (same as the longfield?) Super easy install. The problem was when I slapped the knuckle on the USPS side and forgot about the wiper seal completely... I actually ended up cutting the rubber seal and installing the cut part up top, and the metal gasket split part opposed to it. Test drove home and we'll find if it works because I was too tired to check.
As mentioned above, i'd also consider replacing studs (x8) on the steering-arm-to-knuckle interface. At a minimum, clean threaded holes copiously of any grease. When you reset studs into the holes, i'd avoid threadlock. Just smear some rtv into the top thread space from within the knuckle cavity. This will prevent oil from penetrating down into the stud threads in the event you have an axle seal fail. Having the steering studs loosen on you in no bueno.
