axle part compatibility question
Reno, NV
Found a local wrecking yard with a few 80 series cruisers in it and I want to pick up some spare axle parts for the trail. My list includes a single rear axle shaft (L&R are identical?), a L and R front axle shaft, and a single birf. My 80 is a '94 with no factory lockers. Did some searching and it looks like any 80 series (including 91-92) should work for the front axle components, but I need a 93+ rear due to the change from SF to FF. Does this sound right? Does it matter if they were e-locked from the factory? Just want to clarify before dropping $400 on non returnable parts.
No left and right rear axle shafts are not identical. Just pull the rear from the same type as yours. If full float get a full float, if yours is semi float get semi float axle shafts.
Thanks... Did not know that about the rear axles shafts being different. So all 80 series front axle components are the same, regardless of FF or SF in the rear?
it is an offset rear axle, they are different lengths.
The 80 front axle is the same. You will need R&L axles and 1 birf, if you are planning on wheeling it that hard, also get 2 drive flanges.
Thanks again. Might as well grab those drive flanges too. Planning on a couple tough trails this summer (Rubicon and Dusy Ershim) and would feel better with as many spare parts as possible.
