Automatic Transmission Fluids (ATF) full 12qt flush & set level, 100 series.
come to think of it, i didn't check the bubble level again after i put the AHC in high...
edit: just checked and even in high, it's dead level on the frame.
i put a level on my frame before i started and it looked dead level. i did put the AHC in high so i could have more working room under the truck - maybe that have affected it. should i find a garage to park in and try again?
do you think it's safe to drive it right now?
I recently did 12qt flush for the second time, this time on my second 06 LX. You are correct, if you drain the pan you'll get around 2qt out. If you remove the pan you'll get another 1-1.5qt out of the pan. So you're probably ok since you're not counting the 1- 1.5 qts that remained in the pan. In my rig after all was done and counted, we removed 11qt and filled 12.3qt (exactly what manual states). My fluid was pretty dark, probably never changed before. If it was, then it was a long time ago and probably undefiled. I overfilled by one quart (13th) and used Tecstream for temp reading, got it up to 106 and drained 2/3 of a qt. The way I counted old fluid is I used one unopened ATF bottle by marking its factory filled level with sharpie, I later used that empty bottle to measure everything that came out of the tranny.
To say one got out 10qt and add 12. For sure you'll get 2 qt out on level check, if A/T was at correct level before you began. One could get out 100 qts and add 102 qts. They get same results (2qts over), if AT level was correct in the first place.
I'll focus on 04-07 no dipstick. Although no real any difference in 98-03. Other than we can easily check A/T level pre flush, via dipstick.
First I'll say: I've flushed more A750f (03-07) A/T then I can remember.
In the 04-07 (no/dipstick). I don't often check level before draining the pan. Why; BK1 CAT, gets to hot for me to R&R fill plug. Yet I can say I'll find them ~1/3 qt low 95 out of 100 times. How do I known they're low, without checking level first. By very accurately measuring how much comes out, and how much I put in at same time as it comes out. Understand here. We don't drain and pump out all fluid until A/T dry. Then add. We add qt. by qt., as we remove. So A/T is never run dry. We're at most, ~1/2 qt low at any point engine running during our flush.
I get 3qt. from pan, every time. Even if A/T a bit low, I'll get 3 qt. on level ground. Even if AHC, in H. I get the same results.
How do I known, what level was, if not check pre-flush. By how much comes out during level check.
I can flush out 10qt., 12qt., 18qt., or even 100qt. The trick knowing exactly what has come out and exactly what I've put in.
The 04-07, was under filled at factory, by ~1/3qt. When I flush, I stop flushing, once 12 qts. out and 12.5 qts in. I work to stay 1/2 qt. over filled, during the flush.
Recap of a flush:
  • Engine off and cool, drain A/T pan. Getting 3qts while on level ground. Replace drain plug with new washer, torque to 15ft-lbf.
  • Remove fill plug and attach fill hose (04-07).
  • Add 3 1/2 qt. to pan, through fill hose.
  • Remove A/T cooler hose (PS near top of rad) from metal nipple coming from A/T oil cooler radiator (smallest of the three radiators, in front of other two).
  • Attach catch hose to out flow nipple coming from oil cooler rad, and run to catch can.
  • Start engine and idle.
  • Add ATF in through fill hose, as ATF pumps into catch can. 2qts pump out, as I add 1 qt in fill hose. Stop engine, stopping ATF from pumping out. Add 1 qt. more, while engine off.
  • (At this point I've 5 qts. out 5 1/2 qts in)
  • Start engine 2 qts out as I pour in 1. Stop engine add 1 qt.
  • (At this point I've 7 qts out 7 1/2 qts in)
  • Start engine 2 qts out as I pour in 1. Stop engine add 1 qt. Note: by now ATF is looking much better.
  • (At this point I've 9 qt out 9 1/2 qt in)
  • (At this point I've 11 qts out 11 1/2 qts in). Note: by now ATF is looking very clear, like new.
  • Start engine 1 qt out as I pour in 1/2. Stop engine add 1/2 qt.
  • (At this point I've 12 qts out 12 1/2 qts in)
  • Reattach return hose to nipple coming from oil cooler rad. Place hose on nipple at same depth it came off. Place clamp, on hose. in exact same impressing on hose. Use a flash light.
  • Remove fill hose and replace fill plug.
Then when I check A/T level. I do so with engine at or near op temp (ECT at ~184F >), and when A/T #1 fluid temp, is coming up reaching 97f.
As I load (foot on brake, increase RPMs to ~1,200 while in a forward gear (D-1)) A/T, shift through gears slowly holding in each. Where I can see, A/T #1 & A/T #2. A/T #2 always goes up faster and higher, then A/T #1. As ATF #1, start to near 95F, I'll shift to P and idle. #1 continues to climb a bit and A/T #2 starts to drop. This is AT fluid temp equalizing, throughout the system. Note: If A/T #1 falls back, I'll load A/T again. Once I feel A/T fluid nearly equalized. I'll crawl under vehicle with tech stream. As I watch as A/T #1 raising and A/T #2 dropping. I shoot for #1 at ATF 97F and #2 ATF at ~106F<. I remove check plug.
At this point a get a steady flow from check plug, not just a drip. I'll catch maybe 1/8 qt to 1/4 qt. from check plug. Yet, I'd over filled by 1/2 qt. or more. This tells me, the A/T was low, ~1/3 qt.
More than ~1/3 qt out, of check plug at ATF #1 97F. I know it was over filled, by whatever extra beyond ~1/3 plus qt.
No flow, I'll take A/T #1 temp higher. To see if I get flow before hitting 115F. These are A/T that were lower, than the factory under fill.
When low, without dipstick. I'll add through cooler return line. Same hose, I pulled off nipple, on PS near top of rad. I use a very large syringe, to force in AFT in return hose.
I like to set level as high as reasonable. So I shoot for lowest ATF #1 temp of 97f. Even a bit lower temp is oaky. 1/3qt over is fine. Some AT shop like 1 qt over.
Did this 07LX yesterday.
re your first point: agreed 100%; however, why would i only get 2 qts out of the pan if it was on level ground? it seems like that is the real issue here.
also, on my version of TS, i only see one AT temp - can i just use this reading or do i really need #1 and #2 to converge? (which would require me getting a different reader)
i think i would be more at ease if i was able to get 1+ qts more in than out, but it seems i was only able to put in [keep in] exactly what i took out, which just seems odd for a truck with 250k+ miles.
Recap of a flush:
Ensuite, je vérifie le niveau de la transmission automatique. Je le fais lorsque le moteur est à température de fonctionnement ou presque (température du liquide de refroidissement à environ 84 °C), et lorsque la température du liquide de transmission automatique n° 1 atteint 36 °C.
Pendant que je charge la boîte automatique (pied sur le frein, régime moteur à environ 1 200 tr/min en première (D-1)), je passe les vitesses lentement en maintenant chaque rapport. Je peux observer les niveaux de température de la boîte automatique n° 1 et n° 2. La température de la boîte n° 2 monte toujours plus vite et plus haut que celle de la boîte n° 1. Lorsque la boîte n° 1 approche les 35 °C (95 °F), je passe en position P et laisse tourner au ralenti. La boîte n° 1 continue de monter légèrement tandis que la boîte n° 2 commence à baisser. Cela indique que la température de l'huile de boîte automatique s'égalise dans tout le système. Remarque : si la boîte n° 1 redescend, je charge à nouveau la boîte. Une fois que je sens que la température de l'huile est presque équilibrée, je me glisse sous le véhicule avec un appareil de mesure de température. J'observe alors la montée en température de la boîte n° 1 et la descente de la boîte n° 2. Mon objectif est que la boîte n° 1 atteigne 36 °C (97 °F) et la boîte n° 2 environ 41 °C (106 °F). Je retire ensuite le bouchon de contrôle.
À ce stade, j'obtiens un débit régulier par le bouchon de contrôle, et non plus un simple goutte-à-goutte. Je récupère environ 0,25 à 0,25 litre par ce bouchon. Pourtant, j'avais mis plus d'un demi-litre, voire plus. Cela m'indique que le niveau d'huile était bas, environ un tiers de litre.
Plus d'un tiers de quart de litre s'est échappé du bouchon de contrôle à 97 °F (ATF n° 1). Je sais qu'il y avait trop de liquide, de la quantité en trop au-delà d'un tiers de litre environ.
Pas de débit ? Je vais augmenter la température de la boîte automatique n° 1 pour voir si le débit revient avant d'atteindre 46 °C (115 °F). Il s'agit de boîtes automatiques dont le niveau était inférieur au niveau de remplissage d'origine.
Quand le niveau est bas, sans jauge, j'en rajoute par la durite de retour du refroidisseur. C'est la même durite, j'ai débranché le raccord côté passager, près du haut du radiateur. J'utilise une grosse seringue pour injecter l'huile par la durite de retour.
J'aime régler le niveau d'huile au maximum. Je vise donc une température minimale de 97 °F (36 °C) pour l'ATF n° 1. Une température légèrement inférieure convient également. Un tiers de litre de plus est acceptable. Certains ateliers spécialisés en transmission automatique préconisent même un litre de plus.
J'ai fait ça hier avec cette 07LX.
Merci 2001LC pour tous vos conseils !
Une question : Quelle température indique un thermomètre à infra rouge braqué sur le carter de la boîte lorsque le logiciel Toyota indique une température d'huile ATF WS à 36°C ? Merci
Only 2 quarts drained out- How long did you allow to drain ? If you leave overnight you get additional fluid draining out-
interesting. i only let it drain for a min or two until the initial stream stopped. i guess my main question is what should i do now? am i good to go or should i do one more drain and fill on a garage floor (instead of my mostly flat driveway)? if i do another d&f, i will let the pan drain for a few hours.
it just occurred to me that i didn't remove the check plug during the drain process - maybe i should have done that to get more out of the pan? i doubt i would get that 3rd qt that i'm looking for, but maybe it would get me closer to 3.
If on level ground, with ~3/4 rake. Engine & A/T, had been off and at rest for a bit. To allow fluid to settle. Or even sat over night. Then I'd assume you were low.
The 98-05, don't give us as many data points in tech stream. Same A/T A750f in all 03-07. Which both have AT1# AT#2 sensors. But the 06-07, gives us more data (PID), through tech stream. 2008- up a ton more PID, blow your mind more.
We set to ATF #1 temp. I talk about both #1 & #2. For 06-07. To illustrate, how temp varies in the system.
98-05 we only see ATF temp #1
No need.
I usually let drain from just drain plug, while I get fill plug out and fill line in, set up catch can, line up 12 qt on my beach, get paper and pen, etc. Maybe 15 minutes. 3qts' even time, from cold A/T that was set near correct level.
If any doubt as to level now. Bring temp up and Recheck:
04-07 at ATF #1 97f to 115f. Add if needed.
98-03 at ATF #1 158f to 176f.
98-03, I under fill until level check. Where I can easily add into dipstick
04-07 I always over fill, until level check. So I don't have to add (in most cases)
My routine is to remove and clean oil pan and filter. You probably should've done that too, it only takes an additional 20-30min tops and $25.00 for the gasket. Also have some trans pan screws available as one of ours snapped when we were reinstalling it, didn't even get to torque it. As for yours, as long as the level is correct you should be good to go, IMO.
My theory on why we weren't able to get 3qts is the shape of the pan. Look at the picture of my pan, it looks like the drain plug is located at the shallowest area of the pan. Perhaps there are several versions of the pan, idk? Again, this is just my theory, I am sure 2001LC knows more and can chime in and explain.
@2001LC is providing details for full system flush- but looks like you are just doing drain and fill which is fine- level check process is the same for either.
So what to do now that you drained 2qts and refilled 2qts.
Engine running bring AT temp to 97F- if you don’t have techstream, IR gun aimed closely ( an inch or two) from the pan will suffice. Remove level check plug- is fluid coming out: none, drip, drizzle, or full stream? Add more fluid if none, dripping- 1/2 - 1qt, recheck after temps can be measured in level check range.
FYI level check plug has a bulkhead that sits higher in the pan than the actual drain plug, so draining from level check in an attempt to get more fluid out wouldn’t help. You can see from VTHlexus picture above.
good to know on the check plug. i actually did the full 12 qt flush but it seems that my initial drain of the pan is what is throwing off my numbers so i'm focusing on the drain & fill part. I will do another drain & fill this weekend and do it as cold as possible (first time i had turned the truck around in the street and pulled into my driveway - engine was under load or idling for maybe 1-2 min before drain). if i get the same result as before, then i can only assume @Vthelexus is correct and there are different pan designs that drain different amounts. truck has been driving fine since i did the fluid change.
^ translation: What temperature does an infrared thermometer pointed at the gearbox casing indicate when the Toyota software indicates an ATF WS oil temperature of 36°C?
I am about ready to flush my transmission.
I am going to try using a 12V pump to pump the new fluid into the fill port rather than using gravity with a hanging funnel. I will see how that goes.
Since I am going to do it by myself there is one bit of data I have not seen, or I have missed it. How quickly does the transmission pumps out 2 quarts of fluid? If I have to be in the driver's seat, I will not see the dump bucket which will be on the right side of the truck. Since noone seems to have mentioned it, I assume that I must be overthinking this.
