Hopefully this won't be too long winded...
Symptoms: Driver's side slips and bangs on sharp turns like in parking lots, etc. Driving straight down the road the driver's side will slip (small pop and the truck darts to the left - yes the tires are aired up the same). Hard acceleration or climbing, the driver's side slips and bangs. Not occasionally, but several successive LOUD bangs.
What I think: The center pin slides in way too easy and doesn't even seem to contact the axles. I have the thickest shims I can buy from Toyota and the gap between the two locker halves are at the small end of the spec. I tried doubling up two thin shims on one side but the gap was way too small and the center pin was off center. (Drove it like that and it worked terrible.) I have several center pins here and they all fit the same.
Interesting: When I first assemble everything, it all seems to work fine. After I drive it and put 10-15 miles on it, the symptoms start back up. I guess the grease I use to assemble it keeps it from slipping.
History: Broke a lockrite and (unknown at the time) bent the rear housing. Replaced the lockrite with another used one and the symptoms started. Thought it was the locker and bought a new Aussie. Same. Replaced the housing. Replaced the rear wheel bearings. Replaced the whole third member with a spare 3.70 I had. Replaced the axle shafts. Basically I've replaced everything there is to replace.
Thoughts? I thought about trying 140wt oil instead of 90wt. I guess a Detroit is next.
