Aussie locker in my '93
Syracuse, Utah
So after almost 8 years of wheeling my '93 with open diffs, I finally put a locker in it last night. I've managed to do some moderate trails (several 4 and 4+ trails in Moab among others) in the past without lockers. I've always been impressed at how well the 80 has done without them. I'm not a newbie to lockers however. I started out with an open 40 and learned how to drive and pick lines before I added a rear locker, and then finally added a front locker and tackled a good number of pretty difficult trails. I'm definitely a proponent of learning how to drive your truck and pick lines rather than just starting out with a super built truck that far exceeds the skills of the driver. I just think you end up with a better driver/vehicle combination in the end, instead of "learning to walk with a crutch" as they say. I like to think I've learned how to control my 80 pretty well up to this point and I'm excited to see how the locker changes things.
I've driven about 60 miles with it and it seems to be acting normally, although this is the first time I've had a solid locker. Always had ARB's in the past. I can hear it ratchet on slow, tight turns and it's accompanied by a very slight "bump-bump-bump" as it ratchets. From what I've heard, this is normal behavior for an Aussie locker. Is that correct? Other than those tight turns, I can't even tell it's there.
Getting stoked to try it out in Moab next week!:bounce: I'd love any feedback from other Aussie locker users.
I get the same noises. Every so often it will make a big noise on a turn, but that is rare.
Mine makes some noises as I let off the gas around a turn on the freeway and also during tight turns around town ~ But other than that, it's solid
Two years and still solid.
Appreciate the responses. Sounds like everything is normal. The weird thing is that it's so unnoticeable that I find myself wondering if it's actually going to work on the trail.:hhmm: Guess that's a good thing.
Funny story,
I put mine in last year a few weeks before going to Moab. On the first trail I ran I was climbing a slickrock ledge with a sandy approach. I was looking forward to walking up it instead of using the skinny pedal. Nothing happened except rear wheel spin. A few seconds of disbelief as this shouldn't be happening. I was very disappointed.
Then I realized I hadn't locked the center diff. :doh:
All went great after that. :lol:
Exactly why I never understood the Pin 7 mod. Just put it in low and have the CDL lock automatically. A little less funny story.... Same thing happened to a local guy at Cruise Moab a couple years ago on Launching Pad. He got lucky and figured it out but only after 3-4 failed attempts and nearly rolling the truck each time. :rolleyes:
I'm glad I figured out my mistake, granted it was a little embarassing at the time. Wimpy little obstacle had me scratching my head. :o
I found the pin 7 mod super useful at Moab. On long stretches of slickrock I could unlock the center diff and get less binding on turns. I could just put up with the tire chirping too I guess. :lol:
I have broken 2 rear axles (1 each side) with mine. Still going strong. No signs of damage. :)
I was under the impression that if you have an aussie in rear its always locked whether you have your center diff locked or not.
try to explain...
You know what it looks like right?
Ok, torque from the motor from the franny **edit** tranny, causes a twist on the DS, that twist goes down the pinion and then to the ring gear. The diff is more or less what divides power from there on out.
But the diff is now replaced with the locker. Once the ring turns it encounters resistance from the mass not wanting to roll. The case then only has the cross pin from there to transition forward movement. The cross pin then causes the two sides of the locker to split and hold it with force to the outer pieces of the locker....from there the vehicle travels forward.
The only time the locker releases or "ratchets" FROM HERE ON OUT is when there is no force causing the cross pin to cam the two inner pieces out (with force) against the lockers teeth.
That is what is known as backlash. Read the directions and comments when you have this "Auto locker" you are instructed to let off the gas in a turn causing ???.....backlash. Not having force anymore, coming from the cross pin, to press the two inner pieces out let's the little springs push the inner pieces out causing momentary FREEWHEELING, usually from the over run side.
the case causes the cross pin to force out the locking part of the locker. Backlash lets the little springs unlock and interrupt this.
:hhmm: longest post I ever writ :hillbilly:
Yes I under stand that it releases when you turn . In post number 8 it reads as if you have to turn on your center diff switch to activate your aussie locker
Both rear tires were in loose sand while climbing a slickrock ramp (~30˚ or more I can't remember).
The rear tires had limited traction, so all the torque went to the spinning tires.
Once the center was locked, 50% up front and 50% to the back up I went. It had nothing to do with the Aussie Locker, just operator error.
