The VSC gets disabled with a locked CDL....there is no way to disable TRAC.
The 100 CANNOT send all it's torque to one wheel via braking (A-TRAC) though again, some systems can..
The change was made in 2007, not 08
Some where around early 2007 (production date) they started allowing the a-trac and rear locker to work together. I had a 06/07 built 2007 and A-Trac and the rear locker function together.
Quick question on the 100 series with A-TRAC, is it always on when you are in 4LO? THe FJ has the ability to turn it on and off but there doesn't appear to be a button to do that in the LC/LX (2000+)
Ya, but effectively you still could, right? Here's an example: CDL locked. rear has zero traction. front has traction on the left side. ATRAC inhibits spin on right side, giving *most* power (less whatever is lost to ATRAC slippage) to the left front. Because the CDL has both F/R shafts locked there won't be waste energy on the slipping rear wheels. So all usable torque is effectively given to the wheel with traction. If the CDL were open and both rears had zero traction then all of that energy would be lost to the rear.
The only downside I see is that if the rear were in soft stuff, the slippage allowed by the right front wheel would translate into the rear axel digging.
I guess this also depends upon what the truck thinks the 'target speed' is and how that's calculated.
Stepping out of the theory into the reality, it does work very well - for the vast majority of overland requirements. The only criticism I have is what others have expressed: when you get into some ugly stuff it's not always completely predictable what's going to slip. The art of making the intervention transparent also limits feedback to the driver of what strategy ATRAC is employing. There's been more than once when I'd rather just have them locked and have predictable wheelspin. Maybe I just need more seat time getting used to how it will respond.
Nope! 50% torque goes to a rear wheel and 50% to the front. Go watch my video again. And with the CDL unlocked there's no way to get TRAC to compare and/or transfer power between axles. It doesn't monitor it.
ShottsUZJ100 said:If you have THREE wheels with zero traction and one with, you will not move in inch!
No TRAC-off on the 100 and I can't see a reason why you need it disabled.
i think we need a video demonstrating real world what atrac would do with 3 wheels slipping and center diff both engaged and disengaged.
any volunteers?
OregonLC said:John's video in post #19 did a pretty good job of showing this. With the diagonal wheels unweighted the truck doesn't move. When he locks the rear, the one wheel with traction - right rear in this case - pulls him out. It doesn't matter that the left rear had zero traction; no torque was 'transferred' to the left rear because the entire rear axel was operating as one component and with the center locked the right front couldn't run away by itself.
This should put this to rest:
In order for a traction control system to send 100% of the power to ONE wheel the system would have to be able to send ALL of the power to only ONE axle via the center differential. The only way this is possible is if the traction control system can brake BOTH wheels on the SAME axle at the SAME time. NOT POSSIBLE ON THE 100-Series. This is the ONLY scenario where all the power would be send to ONE axle.
If this is possible on the 100 then my video would have been 100% different. The second the system would lock BOTH brakes on the same axle that truck would move. As you can see it cannot...both wheels with the least traction get the power. Plus, it's always TWO wheels getting the power...not one.
Wait up now - you said "If you have THREE wheels with zero traction and one with, you will not move in inch!"
