the FJ had Atrac system as well, but it worked with the e locker rear diff.
this leads me to believe that the Atrac systems are not the same, or at laest the control systems are not.
My question is how does the Atrac on the 100 series compare to the 4runner and FJ cruiser I have.
Is there an update in the control systems or programing in the 100 series. I have read the sticky and the wiki info about Atrac
Hmm.
If you read up on Atrac then you understand how it works and what it does. More info here on the details of the design:
2000 LX470 - Folder Shared from Box.net - Free Online File Storage
Excerpt:
A-Trac Function. During rugged offroad driving, this function controls the engine output and the brake fluid pressure that is applied to the slipping wheel, and distributes the drive force that would have been lost through the slippage to the remaining wheels in order to achieve a LSD (Limited Slip Differential) effect. As a result, the vehicle's offroad drivability and ability to free itself from the mogul have been improved."
Conceptually speaking...locker and atrac on the same axle at the same time don't make sense. iirc that's why in 2000 when LC/LX got vsc/atrac they lost the rear locker option (iirc that was in toyota design docs). since you have cdl, you have 50/50 split front and rear so even if you get rear axle in the air your front still gets 50% of drive force. if you do not have a locker in the rear obviously atrac could help there.
However in concept I could see atrac in the front helping even with locker in the rear.
Now, when you say your FJ had both, I'm curious about that. I'm not up on the latest of FJs, but according to this link for example (from '06 so maybe it's dated) ->
A Trac/E locker hack (FJ Cruiser) - YotaTech Forums
"Stock you can not engage both the E locker and A Trac at the same time, the E locker will turn off the A Trac."
Apparently there was a mod to allow both together, and maybe later years and special editions enabled both from the factory? Which did you have?
Either way, conceptually I would think it's exactly the same as regular atrac and the only difference is that when the rear locker is engaged, it stops detecting slippage and reacting to slippage in the rear and it only pays attention to the front. So you're right, the software/ecu must be slightly different and if anything I would think atrac + rear locker is more effective than atrac alone except that atrac is always on whereas rear locker needs to be turned on otherwise it won't do anything for ya.
Fyi, I'm speaking from what I understand more than experience so I'm sure others will chime in as well.
Follow up another explanation and thread on atrac and rear locker:
http://www.ttora.com/forum/showthread.php?t=43236
"ATRAC works by sensing wheel spin on each axle. If it senses one wheel on an axle spining faster than the other, it applies brake to that wheel to lock it and transfer the power to the other wheel. Since the rear is locked, one wheel on that axle can't spin at a diffrent speed than the other, so the ATRAC system never activates on that axle, it ignores it. It will then only activate on the front if it senses one wheel spining up there."
For those that like to split hairs: how does this work if the rear axle is locked and in the air where you could say both rear wheels are slipping?
The excerpt above assumes slippage is detected by comparing both rear wheels speed against each other in which case both rear wheels slipping at same rate never registers as slippage. So according to that there's NO difference technically b/w atrac + locker and atrac alone - the rear slippage just never triggers atrac.
I assumed that rear wheels in the air would be recognized as slippage and in this case the ATRAC would have to actively ignore 'slippage signals' from the rear.
The toyota/lexus documentation on atrac behavior i referenced above explains the following:
"Based on the vehicle speed that has been calculated from the speeds of the wheels and the signal from the decelration sensor, the skid control ecu computes the target control speed in accordance with the transfer range.
The ecu compares the target control speed and the speeds of the wheels to determine whether or not a slippage exists. Upon detecting a slippage, the ecu controls the solenoid valve of the brake actuator to control the brake fluid pressure that is applied to the slipping wheel. When the wheel speed becomes lower than the target control speed, the ecu stops controlling the brake fluid pressure.
I don't think that answers anything b/c the question is where does the target control speed come from - is it from 'vehicle speed' or from comparing one wheel speed to opposite (on same axles) wheel speed?
